Question about Samsung PS42P2S 42 in. Plasma Television
Samsung 42'' model ps42s5sdx/xeu bleeps when switched on or off
Dtv ,bleeps when switched on or off & has a verticle line nere left hand side of screen.
  • 280 Answers
SOURCE: Green verticle line on Maganavox flat screen tv
It also could be a bad digital board or the connector.
Posted on Feb 21, 2008
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
romsky79
  • 822 Answers
SOURCE: vertical and horizontal lines from any item on screen, lost sound on Samsung Plasma
check LCD connector.
Posted on May 30, 2009
vinnyq
  • 157 Answers
SOURCE: 2 BIG THICK LINES ON LEFT HAND SIDE OF THE SCREEN
If the lines are vertical and go from one side of the TV to the other, it is most likely the scalar boards. There could be a loose connection from the PDP module (plasma panel) and the scalar boards. Otherwise, the scalar boards need to be replaced.
If the lines are horizontal, then the same thing as above except for the y-drives instead of the scalar boards.
Posted on Oct 06, 2009
ssemul
  • 202 Answers
SOURCE: i have two vertical red lines on the left hand
There is problem with T.CON board or LCD panel.It will confirm by checking which part is problem. Mostly this can cover by replaced of T.CON board.
Posted on Nov 04, 2010
Hi, We have a Samsung F/F model no. SL39WJ1/XEU and the "door open" warning bleep keeps coming on randomly even though the fridge door is closed. Please advise as to possible fault diagnosis.
Those kind of problems can becaused by a bad earth, the same way when a brake light acts like an indicator on a car. Look for any earthing cables/connectors
Nov 30, 2017 | Samsung Refrigerators
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
Feb 20, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
We have 4 cordless panasonic phones and none working only bleep
I switched the phone off at the socket and switched it back on, and it is working now.
Apr 09, 2009 | Panasonic Lands Phones
Verticle lines
You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Similar Problem with Verticle Lines
sounds like a loose cable inside the set, if not it looks like a logic main board
Sep 04, 2006 | Samsung LTN1535 15 in. HD-Ready LCD...
Samsung PS42P2S 42 in. Plasma Television Logo
89 people viewed this question
Henry  Thomas
Henry Thomas
