Question about Microsoft Xbox 360 Console
No picture but sound
Tryed new leads.and tv ok
  • flintymac Jan 17, 2009
    just useing normal leads no HD
    no i have tryed all new leads
    Scholar:
  • 33 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem.
Posted on Mar 05, 2009
  • 40 Answers
Which lead are you using? If it's the HD one, make sure you have each wire in the correct hole. Try changing them around if not.
Posted on Jan 17, 2009
  • Ashley Whitehair
    Ashley Whitehair Jan 17, 2009
    Is it a scart connection?
Since today i have had a snowy sound On channels 1-5 the picture is there, they are ok on just normal tv and they are ok through a vcr but not dvd recorder.....i have tryed settings,changing scart...
Hi, Unfortunately I am a bit unclear on the snowy sound issue but what your describing otherwise sounds like you are trying to watch tv via the dvd recorders built in t.v. tuner, this is possible usually just with a coaxial connection. ( a cable tv cord ) The out to t.v. terminal on back of recorder must be connected to the in from ant./cable on the back of the tv set. all other connections are for higher definition playback. Thanks for trying FixYa, I hope this helps, and good kuck-Prodzilla
Apr 13, 2011 | Televison & Video
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
I HAVE NO PICTURE WHEN I TURN ON XBOX I HEAR SOUND I GET LINES ON TV
sounds like a scrat connection problem.
try using a new scart lead (not R,Y,W lead)
could also be tv scrat connection.
Nov 17, 2009 | Video Game Consoles & Games
Samsung dvdv4600 dvd/vcr: I'm having trouble with dvd. It only plays sounds but no picture in dvd mode.
Check that the scart lead is fully in on the dvd and tv,if ok then try another lead
Sep 19, 2009 | Televison & Video
No sounds when dvd is playing
If you can see the picture ok make sure the scart lead is fully in on both dvd and tv,if ok the try a new lead.
Aug 14, 2009 | Philips Televison & Video
The picture just suddenly disapeared on our tv while we were watching it. There's sound but no visible image.
check the video cable, try replace the cable or interchange it , if the picture ok but sound become missing then the cables is damaged. Or check the large IC resolder the leads.
Aug 08, 2009 | Televison & Video
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
My genisis has no picture!
the leads probably need replacing as these often split inside are you sure the your selecting the right setting on the tv are you using the colour leads red and white or is it scart lead ...............
Nov 19, 2007 | Sega Genesis 2 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
