Question about Stoves Monessen Variable Thermostat Controlled Forced Air Blower Heater
Flame goes out Monessen Ventless fire place Model DLX24.
After lighting the pilot and turning on the burners the flame goes out in about 10 minutes. I have cleaned the unit and have no problems lighting the pilot. This has happened about 5 times so I dont think it is a gas problem.
  • 1 more comment
  • john levanadowski Feb 22, 2009
    I have the same problem with the pilot and flame going out. The pilot lights fine, then it goes out after 10 minutes. I was just wondering if the cleaning of the pilot with a needle worked for the other person that wrote in with this same problem.
    My Monessen ventless heater does exactly the same thing. I was just wondering if the other person that had this problem was fixed with the needle in the pilot to clean it out.
  • boblaws99 Feb 26, 2009
    yes i light the pilot light it lights the it goes up to temp cuts off when get to temp couple times then it just goes out
    Problem Solver:
  • 4 Answers
Take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Posted on Jan 17, 2009
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
I have a ventless heater. The polite will stay lite, but when you turnit on it will only stay lite for 10 to 15 minutes then goes out polite and all
The odp pilot is probably dirty and causing it to shut off due to a false 'low oxygen' situation. Turn the unit off and let it cool completely. Have a drinking straw handy. Locate the opening for the pilot light and use the straw to blow a stream of air across the top of (not into) the pilot assembly. This will create a small vacuum and pull the small particles of dust out of the pilot head. Re-light the pilot light. Note that it should be much stronger and 'bluer' than it was previously. Turn the heater to 'on'. If this does not solve your issue, I would replace the thermocouple. Hope this helps.
Jan 18, 2011 | Vanguard International Blue Flame - Large...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
857 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
