Question about Brother LS-2125 Mechanical Sewing Machine
Threading lower bobbin
I have a brother LS-2125 sewing machine which I havent used for a year. I am  a beginner. When I try to thread the lower bobbin using the picture and info in the manual it doesnt seem to make sense. I am unable to thread it under any tension and when i try to thread it through the delivery eye it is at the top rather then the bottom as in the diagram. I am not sure if I have swapped the bobbin case with one from another sewing machine ( are they all different?) It does not seem possible to thread it the way the diargram shows and when I try different ways it does not pick up the thread or when it sews it has loads of extra thread on the underside of the material.
  • mamawpebbles Jan 17, 2009
    My problem is similar, but I know how to thread the bobbin. The upper thread will not grab the bobbin thread to pull it up through the hole. I have tried everything I can think of. Please help??????
  • Anonymous Mar 30, 2014
    never have used a machine that uses 4 different threads
  • 323 Answers
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
Posted on Jan 17, 2009
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
My bobbin thread keeps bunching
try changing the needle
rethread the machine top & bobbin, using every thread guide
make sure the thread has not come off the thread take up lever
here's a link for a manual
Jul 17, 2012 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps breaking and underneath not sewing right
There may be a broken thread in the bobbin case effecting the lower thread tension. clean all parts and determine if the upper thread or lower thread is breaking if cleaning does not help. double check your machine threading and bobbin installation direction. : this site has many operator manuals if the above suggestion does not help.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a brother LS-2125 and the thread from the bobbin is not catching and is not being pulled through.PLEASE HELP! i need it for an assignment! :)
Here are some things that may fix the problem:
1. First, replace the needle
2. Next, remove the thread and completely rethread the machine
3. Remove the bobbin, clean any lint or thread from around the bobbin, and replace it.
Try sewing again on scrap fabric.
I hope this helps.
Apr 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have this machine brother
You need to either adjust the tension or ensure that you have routed the bobbin thread properly.
Apr 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
May 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
How do you thread the bottom stich on a brother sewing machine?
most of the newer machines have a drop in bobbin that the bobbin turns anti clockwise if it is in correctly lower your needle foot and it should pull up the thread.
Sep 20, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin
all manuals for a brother sewing machine are downloadable at
Apr 02, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
592 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
