Question about Microsoft Windows XP Professional
Windows xp sp2 reboot
to start off this is a problem with windows registry, i just need someone who can guide me to the right spot instead of me trying to search the entire windows registry.
I want windows to reboot when I ask it to do in the start/ shutdown menu.
I also had the problem with the power off, but someone already guided me to the registry key of that.
it shows windows is shutting down " (or something like that, my xp is dutch) and after a few seconds it should reboot, but it doesn't.
can someone tell me where to look.
    Scholar:
  • 96 Answers
You can start by downloading GUIDED HELP .
This application is provided for free in the Microsoft Knowledge Base.
The registry is a volatile environment to enter without prior experience
or the presence of a full backup.
Startup and shutdown issues are addressed by a variety of registry keys
and you can destroy your system with good intentions. This is an area
best addressed by Microsoft as I have seen mixed results with so-called
registry cleaners. Also get a full understanding of how to use ASR
in Windows XP.
Hope this gets you started.....................Nate P.
Posted on Jan 17, 2009
When installing Norton Ghost 15.0 onto a XP machine I get the following error message. "Error 1606. Could not access network location 0\."
This is a fairly common problem in Windows XP, especially with SP2. The most common method that fixes it is to delete some registry keys.
Click on Start-Run, type regedit (without the quotes) Navigate to this registry path:
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
Clear the key: Recent (right mouse click on the key/folder, choose Delete) Close the Registry Editor and restart the computer.
Apr 15, 2011 | Symantec Norton Ghost 14.0: Windows
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Windows xp boots but the desktop will not come up
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 01, 2010 | Computers & Internet
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
Disabled task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
http://support.microsoft.com/kb/q227302/
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
c. Reboot the computer.
May 23, 2009 | Microsoft Windows XP Professional SP2
Registry Editor, Task manager, Command Prompt Disabled
hi, your computer is attacked by virus .install some antivirus and scan the system to resolve this problem .
Dec 17, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
