HEAT PUMP WILL NOT KEEP UP WITH THERMOSTAT SETTING
EVERY THING IS RUNNING OK. POWER IS ON IT IS -15 DEG. OUTSIDE NOW. WHAT DO YOU THINK PROB. IS?
  • johnnyo_13 Jan 18, 2009
    i have a 24k heat strip installed in the unit. should i check to make sure it is working ? and should i have installed the outdoor thermostat, and would that help?
  • johnnyo_13 Jan 19, 2009
    THANK YOU ALL FOR YOUR HELP
    President:
  • 2,559 Answers
Heat pumps in cold climates suffer a number of limitations stemming from the fact that they are designed for air-conditioning applications. As climates become cooler and heating becomes more of the primary HVAC function, one may find that conventional heat pumps lose capacity and do not satisfy the load of the conditioned space. In colder temperatures, a conventional system’s need to defrost can further detract from heating performance. The use of resistance heat or fossil fuels to supplement or replace the vapor cycle. The additional use of supplemental heat to temper cold air blowing into the space during defrosts. As it gets colder outside, the delivery air temperatures inside begin to fall when no supplemental heat is being used. Supply air temperatures that are warmer than the return temperatures add heat to a space, but discomfort occurs when these supply temperatures drop below skin temperature. The air movement can feel cool or even cold. While the heat pump may be operating exactly as intended,the consumer will desire a more comfortable environment.
Please rate this solution
Posted on Jan 17, 2009
  • Randy Hough
    Randy Hough Jan 19, 2009
    The electric heat should automatically engage if the temperature on the inside thermostat is set more than 15 or so degrees above the current inside temperature,If it is not engaging,you should have an emergency setting on the thermostat that you can switch it to.This will stop the heat pump and allow for electric heat.The outside t-stat is not a problem.
I have a 5-ton Nordyne heat pump. The compressor has quit working. How can I get the emergency heat strips to come on using emergency heat on the thermostat.
Your thermostat should have an emergency heat setting. Putting the thermostat in that position should make the electric heat strips only work and keep the compressor from coming on. If your thermostat doesn't have an emergency heat selection disconnect the compressor outside at the power source. Turn the thermostat 5 degrees Above the Rim temperature the electric heat strips should come on.
Jan 02, 2018 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Engine overheating. no heat coming from heater, OK on short 10 -15 minute runs but any longer and it rises fast. steam coming from passenger side under the engine, no visible leaking. assume thermostat is...
the 180 thermostat will give you better heat, but the 170 will keep your engine running cooler, either one will work, as far as the gasket goes if you don't know which one to get you can simply get gasket paper and cut one to fit, it's cheaper that way anyhow. If the thermostat doesn't fix your problem you probably have a blown head gasket, I lean toward that anyway, but as the thermostat is a cheaper fix I would try that first.
Mar 27, 2011 | 1999 Chrysler Cirrus
My heat system is running ALL THE TIME, and the temperature room is 66 and I set my thermostat at 68 BUT IT NEVER RISE THAT TEMPERATURE. Please help me 'cause i all ready call an expert and he dind't fix...
Check at your thermostat for a supplemental heat setting. Your repairman was right in that a heat pump will not effectively extract heat from the outside when the temperature is very cold. The supplemental heat setting allows the heat strips to be used, operating like a normal electric furnace, when it's too cold to work as a heat pump. Take a look, and re-post if you need to.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 04, 2011 | Goodman CLQ36AR49 Air Conditioner
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
May 11, 2009 | Ruud UBHC Air Conditioner
Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Mar 11, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
