Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Standby Led blicking 4 times
The tv wouldn't come on
  • 827 Answers
This is more of an explanation than a solution, but it might be useful to you:
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking,
this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action
required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of
a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses
are those, which you will see for each of these faults on a diagnosis screen described later in this article.
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and
VDR601 (should show open).
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground,
or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a
short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is
also a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on
the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen
slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 &
516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety
shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406
audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback
transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or
Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times
you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -
12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors
are bad, check R8051 and IC8005, also on the "D" board.
Source:
http://www.agoraquest.com/manual_files/understanding_sony_blink_codes.pdf
or
http://209.85.229.132/search?q=cache:tj-DDhwxscoJ:www.agoraquest.com/download.php%3Fop%3Dmydown%26did%3D31+FD+Trinitron+WEGA+KV-24FS120+standby+led+blinks+4+times&hl=en&ct=clnk&cd=3&gl=uk&client=firefox-a
I guess you could try and order some schematics from Sony and have a go at fixing it yourself, but if you are not proficient in electronics, I think the TV repair shop should be your next stop.
At least you can tell them that there's a problem with No vertical Deflection, and that they should check components IC1509 and Q1505.
Good Luck!
Chris (ziraffa)
Posted on Jan 17, 2009
My jvc crt tv blicks timer led but not turning on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 01, 2014 | Televison & Video
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I am looking for a friend about his tv the standby button blicks 10 times what does that mean
Hi:
If this is a panasonic type television the this code is related to a failed power supply unit. Especially if its a LCD and or Plasma.
Jul 02, 2010 | Televison & Video
TV will not power on,reset light is blinking and continues after following reset instructings
Probably needs a DM board.This is avery common problem and the board may not be available anymore.Sometimes you can repair them by replacing bad capacitors on the DM board.
Nov 04, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
Code to enter service mode
Forget the service mode. The tv power supply regulator has probably failed.
Oct 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power on but no pic or sound just the power LED blicking green
I replaced the flyback transformer and horizontal output transistor and works great.
Jul 01, 2008 | RCA F36650 36" TV
Sony kp-53s10
Power supply or scan failure is the usual cause. You will require service for this set.
Jerry G.
Apr 13, 2008 | Sony KP-53HS10 TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
