Question about HP Wireless Optical Mouse
HP/Compaq 5187URF2+ Wireless Keyboard & Opt Mouse
Keyboard Spacebar Sticks and other keys
sandrew
  • 2961 Answers
SOURCE: Setup of HP wireless mouse.
Just in casre you dont have the latest driver, click below:- http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bph06267&cc=us&lc=en&dlc=en&dlc=en&lang=en Or have a look at this link for troubleshooting http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00006821&cc=us&lc=en&dlc=en&dlc=en&lang=en
Posted on Aug 22, 2007
SOURCE: How do you open the mouse to replace the battery
quite easy look on the bottom holding the mouse as you would in use . at the end nearest to you , you will see a arrow pointing to the left under is the battery release slider move it to the left then slide the top cover backwards and reveil the batteries, observe polarity when changing batteries
yours
Reg Taylor
Posted on May 07, 2008
yooperbud
  • 8637 Answers
SOURCE: Logitech Mouse Not Working
Normal 0 Are your batteries in the Keyboard and mouse good?
You probably have gotten it working by now but here is a way to get it work if not.
Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Posted on Jan 15, 2009
yooperbud
  • 8637 Answers
SOURCE: HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
lonewolf1996
  • 142 Answers
SOURCE: wireless mouse not working
You can use them both at the same time.Make sure the batteries are good.There should be a sync button on the bottom of the mouse.you need to check the wireless receiver to see if there is a button on there as well.If there is you need to push the button on there first,then the mouse.
The easiest way to fix a sticking key is to remove it from the keyboard and clean it out.Then replace the key.
Posted on Sep 02, 2009
Spacebar problem on dell laptop
Suggest replace Keyboard
Really
Need guidance with that post the Model Series Number
It's on the Bottom of the laptop
Example;
Aspire 5535-5315
Acer = Manufacturer
Aspire = Model Series name
5535 = Model Series Number
5315 = Model Number
Post back in a Comment
Regards,
joecoolvette
May 02, 2013 | Dell Inspiron Computers & Internet
Spacebar seems stuck/misfires
It is most likely a cleanliness issue.
Most of the time when a key 'sticks' its because its either broken, or there's some sort of dirt under it, making it malfunction.
A quick and easy way to try to fix this is to buy the keyboard cleaner at a wal-mart, target, kmart, best buy, etc...Its an aerosol that you spray like WD40 into the cracks between the keys to remove dust and such, it does not leave a residue and is basically just blowing air into the cracks.
Alternatively, you can take a water bottle, empty the water (and make sure its completely dry) and then poke a small hole in the lid, then stick a straw (I suggest a thin straw, like they use for Gin and Tonics and restaurants.) into the hole and hold it in place. Then put the straw down by the key and just squeeze the bottle hard and fast to shoot air down into the crack.
If its still failing after that, you'll probably want to take the key off and manually clean it. To do this, look up your computer on the company's website and look for the maintenance manual (or if you still have all of your computer's documentation, you can look there). It should tell you how to safely remove keys and then replace them.
That's all I got, hope it helps. If you still have problems, then I suggest getting an external keyboard (you can pick them up at a Goodwill for five bucks tops) and use that to see if its an issue with your computer, or the keyboard.
Jan 15, 2013 | Dell Latitude E4310 Laptop
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
Where is the "fn" key located on my hp keyboard model # 5187URF2 ?
I have a Logitech and the Fn key is on the right side in between the Alt. key and the Ctrl key. to the right of the space bar.
Jun 10, 2010 | HP Wireless Optical Mouse
The spacebar brings up help info
you need to remap your keyboard. ask Windows help for complete instructions.
Oct 27, 2009 | Microsoft Natural Ergonomic Desktop 7000...
My 5187urf2 keyboard has stopped working. The signal light flashes when I press a key. Also the capslock light is flashing. Any ideas?
the keyboard is recieving power> but if its not working then it can either be the port or the keyboard> swap the mouse and keyboard ports> see if both work or not> if after the swap the mouse works on the keyboard port then <>>>> keyboard is bad>>>.
Oct 15, 2009 | HP Computers & Internet
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Wireless mouse not working
Sep 02, 2009 | Dynex Optical Mouse
HP Wireless Optical Mouse Logo
870 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
