016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
- PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
- PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER the 3 digit code for your brand.
- You should receive 2 quick flashes after entering your code.
- PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your
brand of equipment, or
your brand is not listed, and you are still not
able to get the unit to respond, try the following procedure
to search
for your code.
- PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE slowly between the POWER key and the
DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On
VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search,
You may have to press this sequences of buttons up to 100 times to
search the entire library of codes.
- When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
- PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
- PRESS 9 - 9 - 0.
- PRESS 1, carefully COUNT the number of blinks. (1st digit)
- PRESS 2, carefully COUNT the number of blinks. (2nd digit)
- PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Insignia ns-lcd37
i cant program my fios remote to operate the tv. i am using 0198 and it doesnt work
