Question about HP Compaq FS 7550 17" CRT Monitor
Compaq 7550 Monitor no display
I have a compaq presario with a Compaq 7550 monitor that the green light comes on after blinking for awhile but the screen never comes on. I have no idea if this is the monitor or signal from the computer or what. The power was off just before this happened.
  • May 11, 2010
    With the monitor turned on, disconnect it from the computer. Does anything come up on the screen?
SOURCE: Screen color changes, white becomes yellow.
Try moving the cable that goes into your graphics card i had a connection problem with mine, i either moved my tower or the cable to correct the problem
Posted on Nov 04, 2007
I think you need to clean your monitor inside of it, dust can conduct heat making the screen material active and creating the yellowish tint to the screen.
I don't think it's a connection problem, becuse it if was you would not see nothing on the screen at all but only one connection error message or like 3 colors.
so you have to open it and clean it I usally use a hair dryer to clean inside stuff or a paint brush.
try cleaning it, but if you have special screws that you have to take out from the monitor you then have to buy special tools for those screws.
I had the same problem right now with my monitor, it's 7 years old, and decided to get a dell flat screen 22 inch.
but that's what I think is your problem, it's either dusty or oxidized meaning different oils are layered inside on the circuit boards. which are like insulators
Posted on Nov 24, 2007
worldvet
  • 859 Answers
SOURCE: Compaq 1720 Monitor
You may need an adapter plug. They come with new monitors so ask around to see if anyone has one you can borrow.
Posted on May 11, 2008
eagle338
  • 4889 Answers
SOURCE: Compaq 1501 15" LCD Monitor ( Blinking Display)
Hi BOY! :P
Check if there is anything wrong with the video input cable to the monitor. If not then you should move ahead with the replacement of the ceramic fuses. There should be around 6 of them in most monitors i have fixed. They will look like this(click here) They should cost you around 1$ each.
If none of these work then your monitor's inverter board is probably screwed and needs to be replaced. should cost you around 30-60$.
Posted on Aug 30, 2008
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
My speakers on my compaq 7550 have no power. when you turn on the sound, the green light is not lit up, so they are not getting power.
Have you checked the Power supply adaptor and the power cord plugs? If all are okay, then the power supply adaptor is the problem. Change the power supply and it should work.
Mar 05, 2011 | Compaq FS 7550 17" CRT Monitor
Compaq 7750. Can I attach speakers to this model? I was given it but it came without speakers
Compaq FS 7550 has no built-in speakers. However, the FS7550 monitor comes with a pair of detachable, independently powered JBL Platinum Series speakers, which can be mounted on sides on the monitor.
Click here for more information
CreativeTECH
Jan 17, 2011 | Compaq FS 7550 17" CRT Monitor
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
Nov 13, 2010 | Compaq Presario 5000 PC Desktop
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
My monitor green power light is on and stays on, but no graphics
The picture board on your monitor is faulty or bad, since it goes graphics is displaying after booting, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity a service center to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Compaq FS 7550 17" CRT Monitor
Green light comes on and the fan but monitor will not
Hello.
Could be the monitor or your Presario's VGA card. Swap the monitor with another system to see where the problem lies. If another monitor works on your system , it's your monitor. If another monitor doesn't work, then the problem is the VGA card.
Hope this helps.
Nov 10, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Image on my monitor does not fill the how screan.
Use the control panel in front of the monitor to adjust screen.
Here's the manual for your monitor:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00385928/c00385928.pdf
May 22, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
Compaq 7550 screen issues
Your monitor is having thermal problems. Some part in the horizontal circuit is changing value as it warms up, and you're seeing the effect. It's possible to troubleshoot this kind of problem by using spray chiller to cool down parts and find the culprit, but labor and parts would probably mean you're better off just replacing it. New LCD's are quite cheap today, and you'll gain extra space on your desk if you get one.
Dec 28, 2008 | HP Compaq FS 7550 17" CRT Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
HP Compaq FS 7550 17" CRT Monitor Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
