Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Flashing screen The top drawer of my dishwasher will not run. The outside control panel flashes with different times and will not reset. There a three light lit up on the inside control panel and they also will not reset.
  • 1 more comment
  • Anonymous Nov 27, 2007
    Our top drawer will not run either. The green light goes on and beeps then turns the power off. Help!
  • Candodigger Dec 30, 2007
    Our top dishwasher will light up and beep and then shut off . It will not run. the only way to stop this is to leave door open a little. there is no error codes on display nor can i get any to come up ???? I can say this is 1st problem in 5 years. Please HELP
  • Anonymous Mar 27, 2014
    All lights on control panel are flashing
    Problem Solver:
  • 5 Answers
Hi there, Sounds like your product is in display mode so you will need to switch the product off for 10 seconds at the wall and switching it back on to reset it. Kind regards Carmen
Posted on Aug 09, 2007
    Novelist:
    Scholar:
  • 84 Answers
Hi melkins37...the following URL will take you directly to the Fisher & Paykel Troubleshooting Guide that is applicable to your issue. http://www.fisherpaykel.com/global/customer-care/trouble-shooting/dishdrawer.cfm?CFID=11155359&CFTOKEN=65076032#12 Also, if you no longer have your User's Guide, a copy may be downloaded by clicking on the following URL: http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf I hope their information provides you with a swift remedy......goodluck my friend.
Posted on Aug 03, 2007
SOURCE:
Fisher & Paykel dishdrawers - no power at all to the top drawer
Try and do a power reset to the dishwasher. This means turn the mains power off to the dishwasher and back on again. If there is no mains socket under the kitchen bench then maybe do this from the mains contactor switch in the meter box. If there is no difference to the behaviour of the top drawer then the controller has most likely packed up. You can test things out by taking controller from bottom drawer and putting in top drawer. But this requires some experience with taking out the front covers of the drawers, taking out the connectors and putting back. If you mix the connector connections etc you can cause more damage. Take photos as you go along. Make sure the dishwasher is disconnected from mains power when you are working on it.
Feb 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Top drawer does not work and bottom drawer flashes on and off
I would need more information to assist you. Drawers run and act independent of each other, the only share to things, drain hose as they connect to each other under the sink, and the power board in which also detects water in base pan. If you have a digital display, what is currently displayed? You lower drawer flashes? What is it flashing F1? F1 is a flood in base pan, F2 is a bad motor. I would need some more detailed information to assist you. Also does you model have panel like wood? This would mean you don't have a digital display.
Please get back to me so I can help you
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 22, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Jan 31, 2009 | Dishwashers
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel dishwasher double drawer problem
Hi there FM, Your Dishdrawer is it intergated or does it have a factory finish on it? This will help me ask the next question? Kind Regards Carmen
Aug 08, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
365 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
