Servis M6002W wash control button sticking
Hubby cannot remove panels to check the problem! has not got a clue...
Remove two screws, using allen key, and also remove two m6 hex head long bolts. top comes off easily
Posted on Aug 22, 2010
Servis washing machine one of the buttons on the control panel have pushed in and won't work anyone know if this can be repaired?
You can switch off the washer and remove the panel carefully, The buttons are normally held by small plastic hinges and it could have been damaged. You can remove the switch panel from inside and keep the buttons in place with a soft glue before the board is replaced back to place.
Aug 22, 2013 | Washing Machines
I NEED TO KNOW HOW TO OPERATE servis M6002W WASHING MACHINE
No manual when the machine was delivered?
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual (service or otherwise), parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 10, 2011 | Washing Machines
Will only perform a duvet wash and keeps beeping
your fault can be caused by the switches on the control panel sticking due to the fact the panel is not totally waterproof water from the sink in the kitchen can find its way into the panel it then corrodes the switches on the panel because the duvet button is at the bottom of the panel it collects water here making the switch stick. if you are able to remove the control panel yourself then you will be able to get an electronics engineer to fit a replacement switch.if not a call to dyson to repair and test your machine is the best solution
Nov 09, 2010 | Dyson Memory CRO1 Front Load Washer
Machine has got wet inside casing in bad weather -
this machine would need to be tested there are many things it could be unless you are compedent have it checked by an engineer
Jan 16, 2010 | Washing Machines
How remove front cover on pump to see if blocked? - servis m6666
remove pump from machine then 3 screws and it will come apart It might stick a little don't lose the seal
Dec 14, 2009 | Washing Machines
My servis m6755b washing machine door wont open
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Washing Machines
I can not get an instruction manual for servis washing machine model numberM60025
Check inside the control panel - or inside the shell of the machine. Every unit is sold with a service manual attached.
Mar 23, 2009 | Washing Machines
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
My Servis M6000-1 washing machine does not fill with water
Buy a new washing machine, seriously, i had a servis M6002s, only had it for 13mts and it died, it wouls have cost £130.00 to repair. After doing a few online serches for the machine i found loads of other people with th same problem. I was outraged to be honest, granted they are not the most expensive machines out there but if you pay £250.00 for a washing machine you expect to get at least 3 yrs out of it. Needless to say i won't be buying a servis again, absolute rubbish.........
Aug 22, 2008 | Washing Machines
Front panel removal
make and model number would help, post these details and i may be able to help
Sep 09, 2007 | Washing Machines
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
