Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Where do i Find the heating element on my wd640 washer dryer
I am unable to find a wiring diagram for my hotpoint wd640. The machine is working fine just not drying my clothes. It goes through the normal cycle etc. think its the heating element but where is it hidden?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
On top of the drum there is a metal dryer box. the heating element is connected by 2 wires.
it maybe that a build up of lint has tripped your thermal wire out or the thermistor,(you will have to test the continuity).
Posted on Jan 30, 2009
The dryer does not get warm everything else works fine just no heat seems as though the heating element has stopped working any idea on how to fix this
its more likely to be thermo stat if you take off the lid you will see the dryer unit on top of that there are 2 little round objects with 2 wires on each they are held in with little metal springs if you buy a thermostat kit they are easy to change
Jan 09, 2011 | Hotpoint Aquarius WD640 Front Load...
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
My whirlpool le5700 won't heat up
Depends on which element you mean if itsthe drier side then its up top under the lid if its the machine then its @ the front normally....
Feb 17, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
How do I replace the dryer element on my hotpoint auarius wd640 front load all-in-one
Before you replace dryer element, how do you now it is bad and what tells you it is the element and not 3 or 4 other items that could stop the element from heating? If oyu tested the element directly (and this of course is nearly the only way to know if it is bad) then you obviously has access to it and should see what is involved in removing it. So, I believe you do not actually know if the element is bad. You need to search and test all the controlling items that allow the element to heat before condemning it. I believe you need a skilled service person. Goodluck, macgivor
Nov 09, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a problem with my hotpoint WD640
Check the resistance of the heating element it should be anywhere between 0.6 OHMS to 26.7 OHMS. Then make sure the thermal fuse is not blown. Resistance between it's terminals equals to 0.0 OHM
Update me about your progress
Jul 20, 2009 | Hotpoint Aquarius WD640 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
472 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
