Question about Acer NSK8458AN Keyboard
Hello.MY KIDS REMOVE KEYBOARD KEYS FROMACCER COMPUTER I PUT LETTERS AND NUMBER BACK.BUT DONTKNOW WHERETO PUTCTRLHOMEALT
  • 827 Answers
Maybe you could use this as a guide:
Hope this helps :)
Chris (ziraffa)
Posted on Jan 17, 2009
  • chris grams
    chris grams Jan 17, 2009
    Happens to the best of us :D
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
What are the names of kyboard and its keys ?
it is only for a computer keyboard hope it help from you.
A computer keyboard serves as a main operating tool for accessing and inputting data into a computer. The keyboard features many functions and keys that a user may never use, but is still essential to some users. Understanding the keyboard can improve computer knowledge and use.
QWERTY Pad
The "QWERTY" pad is main sections of letters on the keyboard. These letters are mainly used for typing and also as shortcuts in programs like Windows Movie Maker, Adobe After Effects and computer games.
Number Pads
The far right side of the keyboard features a number pad that resembles a calculator. This number pad is essential for programs like Excel, but can also be used to input numbers as a typing function. More numbers are just above the "QWERTY" keyboard that also feature symbols when the "Shift" button is used.
Arrow Keys
The right bottom of a keyboard features four directional arrow keys. These keys provide navigation through word processing documents and also serve as scrolling functions in web browsers.
F Bar
The top of a keyboard features the "F Keys," a selection of keys that extends to "F12" on most keyboards. These keys serve different functions. For example, "Alt and F4" exits out of a program. "F1" will start the typing helper in word processing programs.
Extra Keys
New keyboard feature shortcut keys at the top of the keyboard. These include shortcuts like "Power," "Sleep Mode," "Calculator," "My Computer" and "Web." Some also include media controls for movies and music.
Aug 11, 2011 | Acer NSK8458AN Keyboard
My keyboard is not working especially a ,f ,j ,l ,g. how do I fix this? help
Every day your computer is exposed to dirt, hair, dead skin and other kinds of grime. This can drastically affect your keyboard's performance. Removing your keys is a simple and effective way to clean the inside of your keyboard and improve keyboard response. This is a simple operation and should only take a few hours if done correctly. This is important to anyone who wants to know how to properly remove their laptop's keyboard keys.
1. Print out or draw a keyboard map of the location of your keyboard's keys. Turn off your computer.
2. Position the laptop so that it is under a lamp or so there is sufficient light shining onto the keyboard. You want to be able to see all the dirt that is under your keyboard.
3. Take the end of a flat-head screw driver and carefully pry any of the letter or number keys off, preferably starting with the "Q" and working your way to the right. The letter and number keys are easier to remove than the command keys.
4. Collect the removed keys into a container so you do not lose them. Take special care when removing the tab, caps lock, shift, space bar, enter, forward slash and back space buttons. These buttons are attached to a small metal pin. It may take a little more effort to remove these, so be patient.
5. Feel free to clean the inside of your keyboard once all the keys are removed. Take a cotton swab dipped in a small amount of alcohol and wipe the areas around the keys to remove the grime and dirt. Use tweezers to remove any bigger bits and pieces of dirt or hair.
6. Refer back to your keyboard map and put your keys back into their right location. Position each key in the center of the plastic connector and press around the edges till it clicks. Feel around a little till it is tight and secure.
I hope you find it very helpful.
Thank you for choosing Fixya.com
Aug 11, 2011 | Acer Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
I have a gateway mx6453.every since i gooked up my wireless gear via usb, the keypad on the laptop has the numbers on the letters UIOJKLM stuck into number ock even when I unplug the wire less. what...
this may sound weird to you but turn off the laptop, remove the bezel, screws and the keyboard. start the computer until you get a keyboard error. enter the bios and restart with f10 and enter. when it restarts, shut off the laptop again. reinstall the keyboard. restart the computer and try to use the locked keys. i doubt the usb wireless caused this. if the keys are still stuck, then the keybaord is faulty. spill liquid on it?
Jan 28, 2011 | Computers & Internet
Keypad seizing..when ever i want to type,some of the keypad hang and i need to hit the letters several times.
It seems that keyboard has started to malfunction.. it happens after some time.. If possible replace the keyboard.. Get a new one from the marke.
In the mean time you can try cleaning the keyboard once, so that if dust on any other dirt is affecting the performance, you can overcome that..
Use a blower to clean that..
Aug 17, 2010 | Compaq Keyboard
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
Jul 20, 2009 | Logitech 9675020403 Keyboard
JUST HLP PLEASEEEEE
Sounds like your keyboard is sticking
Unplug the keyboard and do the following
Look on the bottom you should see some screws, remove the screws and leaving the keys facing down, pop the two pieces apart.
Leaving the electronics aside you can now continue with the following instructions
Ok, once you have the two pieces, all of the keys should stay in there proper place, take and soak that in the sink with some soap and water.
Moving all the keys to get the water to flow through.
Then dry off the Keyboard and vacuum all the excess water off, then replace and screw back together, you should be good to go.
I wouldn't recommend a dishwasher, this could get to hot and melt the keys
Apr 24, 2009 | Gateway 2520796 Keyboard
Several letters on a keyboard have stopped working
Bring it back to the repair shop. They should replace the keyboard.
Dec 02, 2008 | HP Compaq Presario v3000z Notebook
Acer NSK8458AN Keyboard Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
