Question about Goodman GDS80904BNA Open Flame Heater
Gsm080-4 4 blinks on code cover says main limit open or aux limit
Can i check them or not?where are they located. iits been runntssat morning and temp is -12degrees out. iwaited for gas valve to kick on then lite the burners manualy its been running about 4hours now . istopped it now but same thing
    Scholar:
    New Friend:
  • 70 Answers
Sounds like you have a hot surface ignitor that is not working. The ignitor is located in front of the burner assembly. It usually takes two 1/4 screws to hold bracket. If you need and more help just reply back to this solution with your questions and i will try to help you
Posted on Jan 17, 2009
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
Sony klv-v40a10e black screen green light on but 15 blinking red lights after a double power down from electric company
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 20, 2014 | Sony Televison & Video
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
Moved to a place with a 139.53975SRT1 Garage Door and Keyless Entry. Keyless entry stopped working and I cant get code to operate door. All remotes stopped working. Reset codes with Learn button,...
Try this method for programming. Press and hold the button down on the remote while you press and immediately release the learn button. Do this for each remote.
Have you replaced the battery in the keypad? Try this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Post back with your results.
Jan 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Kenmore dryer 500 , model # 110.79522800 . electric igniter turns on and off while dryer is running.
does the flame lite?the ignitor should come on and then the flame lites and will stay on until the dryer reaches the right temp. then it shuts off,if the flame isn't liting no gas is coming in,bad gas coils will do this or the gas valve,most likely it's the coils located on top of the valve,take out the two phillips screws,remove the cover and change out the coils
Mar 24, 2010 | Kenmore Dryers
Blowing cold air and the pilot lite is lite but no burners come on and the on/ off knob for the gas the part that is underneath the knob is making a ticking noise? If that box is the problem can we change...
You have to verify if you are getting 24v to the gas valve. If you are and the burners wont lite then replace the gas valve. They sell em at Sunberg (located thru out the use). If you dont have 24v then check the transformer. If you do have 24v at the transformer, take two wire from the transfomer 24v and put them directly to the gas valve to see if it will light. let me know what happened.
Mar 20, 2010 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
126 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
