Question about Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26in has a "no signal" message on the screen
I have a Proscan 26lb30QD 26in Flat screen that now has a message bouncing around that states "no signal" and the DVD will no longer pull in a DVD. I unfortunatly bought this from Circuit City and bought an extended warranty! Well I am not sure if their is some kind reset button or not but if you have seen this before I really appreciate help. The "no signal" message bounces around like a screen saver may work. Well if any expert may know the answer my 4 year old who watches DVD's on this unit would be so happy. - Thanks Reggie
  • reggie847 Jan 20, 2009
    Ekse thank you for the response but does this mean you have no idea? I am at my wits end with this. I cannot seem to get in touch with anyone. Would you know the number to call to get in touch with ProScan. I have a number 888-976-7225 but this number appears to be out of service.
  • 13,433 Answers
Tv is not getting signal from the source its connected to. If you haven't changed anything and the cables are all ok, I suggest you take advantage of the extended warranty and get it looked at.
Posted on Jan 17, 2009
  • 1 more comment
  • Ekse Jan 22, 2009
    Sorry for the delayed response I've not had any notification of your reply.
    The no signal message on the screen basicly means there is no input signal coming from the source its connected to or its on the wrong channel / input.
    If there is signal ( you can test this with another tv ) and you get the picture from the source then the issue is on the television input and needs service.
    I beleave you can contact circuit city to get the details on the extended warranty - who to call to.
    I know they are closing their doors but I'm outside of US and I don't have a phone number to you this minute. I will look into it and get back to you as soon as possible.
  • Ekse Jan 22, 2009
    Hi
    I have a number for proscan service here
    http://www.oncorpus.com/Support/service....
    for USA - 1-888-977-6722
    If your in canada, open the above link.
  • Ekse Jan 22, 2009
    Also the DVD drive doesn't pull in a disk or give it out. the eject mechanism is probably stuck and the drive would need to be taken apart to inspect and correct the problem.
Proscan 40" LCD-Screen Freezes
The problem is with the set. I would return it.
Jun 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Has a proscan 26lb30qd with no picture.
You need to give a lot more information about the type of set-up youare using with your television. The type of components in the system,like dvd/vcr receiver etc. The type of signal connection you are usingto the television. Cable or satellite box or antenna. If all yourconnections are correct and you are using the remote control correctly.You may have a problem with the video input circuits of you televisionand you should call for PROSCAN customer support at this telephonenumber. 1-888-977-6722. You can also get customer support from theirwebsite. www.oncorpus.com. I hope this has helped you with your problem.
Mar 10, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
55 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
