Question about Samsung SyncMaster 213 T 21.3" LCD Monitor
Red Line I have this monitor and I have a red line running down the left side
  • Nathan Young Jun 21, 2007
    Thanks antiochpc!!
    President:
  • Samsung Master
  • 1,314 Answers
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels. Direct from their site: "The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced. To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call." http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
Posted on Jun 21, 2007
4 Suggested Answers
SOURCE:
Johnboy36
  • 77 Answers
SOURCE: Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Posted on Feb 20, 2008
  • 225 Answers
SOURCE: Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
Posted on May 30, 2009
Mdali001
  • 5 Answers
SOURCE: A red line appears down the right hand side of my
dear friend . .
the line appears due to some tecnical fault of your monitor
if u have still in warranty period then just change it soon
Posted on Oct 06, 2009
Red line on monitor
It's is either a screen or video card issue. Only an apple tech can repair or replace parts as needed.
May 08, 2013 | Apple Computers & Internet
dear friend . .
Oct 06, 2009 | SNK Cibox [email protected] C2201 22 inch LCD...
May 29, 2009 | HP w2207 Monitor
Thin Red Line on Left Side of HP Pavilion DV2000 Lap Top Screen
Majority of time it's the lcd that has a problem which creates the red line, otherwise it's the GPU (video processor).
Try hooking up your computer to an external monitor. If you see the line on the external chances are it's the lcd.
This method of testing isn't fool proof but either way the problem is hardware related.
Let me know if you have any other questions.
Mar 04, 2009 | HP Pavilion dv2000t Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
LCD vertical lines
hi, all the LCD cable contact pins to be cleaned, if still invain then u will need to replace the LCD..
Mar 16, 2008 | Toshiba Libretto 100CT Notebook
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Televison & Video
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Samsung SyncMaster 213 T 21.3" LCD Monitor Logo
698 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
