Question about SanDisk Sansa m240 MP3 Player
Driver I've used my Sandisk before but havent used it in a while and when I plug it in it doesnt show up on the computer. I found it in Device Manager, and its saying it hasnt found a driver software, so I go to find it and it says it found a device software, which is MTP Device but it says the device is not configured correctly. So how do I reconfigure it? Its also saying Code 1... but before I findled with it it said Code 18...
    Scholar:
  • 51 Answers
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Posted on Jan 27, 2009
My mp4 will not show up on the computer it doesn't even synk
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Mar 06, 2009 | SanDisk Sansa e200 MP3 Player
My computer will not recognize my slick mp3 E10 when I want to install music. How can I do this?
Thank you
Mar 04, 2009 | Audio Players & Recorders
PC is not detecting my scansa C250V2. -error- Refresh data base
Thank you
Computerrep
Jan 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Windows Media player will not "Connect a Device"
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer.What i would recommend you to do is to uninstall the device andreinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardwarethen device manager...look for the sansa device..it usually locatedunder portable device..if its not showing there i would recommend youto look for under disk drivesand see if its there..right click on the device and click onuninstall...after you unintall it unplug your device from thecomputer....Then follow this link below to downloadthe portingkit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en.Then check the mode of yuor device to make sure it sunder MTP notmsc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows mediaplayer click on tools, options and click under privacy...clear thehistory and caches...after you finish you can plug the device on theback of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media playerto 11 even though you have done that already..and try to reconnect yourdevice..make sure you have it connected on the back USB>>>
Thank you
Computerrep
Dec 28, 2008 | SanDisk Sansa Connect MP3 Player
My sansa wont be read by the computer
Thank you
Computerre
Dec 26, 2008 | SanDisk Sansa Connect MP3 Player
Problem installing driver
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button. Clicking on the “System Devices” tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.
If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer”"
Jul 06, 2008 | Sony Walkman NWZ-S616F MP3 Player
DRIVER OF SANDISK
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
Jun 01, 2008 | SanDisk Sansa c240 MP3 Player
I cant get any songs on it
Thank you
Computerrep
Apr 17, 2008 | SanDisk Sansa m250 MP3 Player
Sandisk Sanse e250
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...In would recommend thaf you upgrade your windows media player to 11..to do that go to ..www.windowsmediaplayer.com and then click on the download now for windows media player 11...then you want to plug your device in the back of your computer..not in the front..that is very important....once you do that..open up your windows5.gif media player5.gif...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
Apr 01, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
104 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
