Question about Plumbing
Need to replace a targa valve on a astracast targa monobloc tap
I have the necessary valve, but cannot see how to remove the tap cover to insert the new valve
    Problem Solver:
  • 11 Answers
The cover on the outside should pop off, and there should be a crew there, sometimes they are a little tricky to get off, a craft knife of something like that should do the trick
Posted on Feb 11, 2009
Removing steering column shroud on a 2006 sierra 3500, no screws where videos show to remove them there's a recess area but no screws in the locations indicated
Steering Column Trim Cover Replacement
Important: You must check for 2 pan head tapping screws (1,2) in the lower trim cover before removal.
If necessary, remove the 2 pan head tapping screws (1,2) from the lower trim cover (3). Remove the lower trim cover (3).
If screws are not present in the lower trim cover, proceed to the next step.
Gently unsnap the lower trim cover from the upper trim cover.
Important: You must check for 1 TORX® head screw (1) in the upper trim cover (2) before removal.
If necessary, remove 1 TORX® head screw (1) from the upper trim cover (2).
If a screw is not present, remove the upper trim cover (2).
Dec 01, 2016 | 2006 GMC Sierra 3500
Lifter tap on a gmc sonoma 2.2 its a2001
Jan 18, 2013 | 2001 GMC Sonoma Extended Cab
Valve cover won't come off
Follow the detailed procedure mentioned in the link below to remove replace VALVE cover:----
Click the link below:---
For more help on these issues,check the link below:---
Car oil leaks from valve cover gasket?
Lexus RX: Tapping noise under Valve Cover At Low RPM?
---------- How to replace Timing Belt,Water pump And Valve Guides on Mitsubishi Montero
2000 Toyota Solara: Valve Cover Gasket Replacing?
Valve Cover Keeps Cracking?
These details will help.
Nov 23, 2012 | 2006 Subaru Forester
Valve cover gasket, how to replace?
Rocker Arm (Valve) Cover REMOVAL & INSTALLATION 2.3L 4-Cylinder Engines
  1. Disconnect the negative battery cable.
  2. Label and remove the spark plug wires.
  3. Remove the attaching bolts for the valve cover.
  4. Remove the valve cover from the cylinder head. If necessary, lightly tap the valve cover with a soft hammer to aid in removal. To install:
  5. Thoroughly clean the valve cover and cylinder head gasket mating surfaces.
  6. Install the valve cover on the cylinder head using a new gasket.
  7. Tighten the valve cover bolts to 14 ft. lbs. (20 Nm) in a crisscross pattern.
  8. Install the spark plug wires.
  9. Connect the negative battery cable.
  10. Start the engine and check for leaks. Fig. 1: Valve cover and gasket assembly 90953g12.gif
2.8L 6-Cylinder Engine
  2. The following steps are necessary if your car has A/C and if you are removing the passenger side valve cover, if you do not need to remove the passenger side valve cover, skip them.
    1. Remove the A/C compressor belt and the compressor from the mounting bracket located on the passenger side of the engine. Do not remove the lines from the compressor.
    2. Place the compressor with the lines attached on the passenger side front shock tower and secure.
    3. Remove the compressor bracket.
  3. Remove the air cleaner-to-throttle body hose.
  4. Label and remove all necessary electrical and vacuum connections.
  5. Remove the attaching bolts for the valve cover(s).
  6. Remove the valve cover(s) from the cylinder head(s). If necessary, lightly tap the valve cover with a soft hammer to aid in removal. To install:
  7. Thoroughly clean the valve cover(s) and cylinder head gasket mating surfaces.
  8. Install the valve cover(s) on the cylinder head(s) using new gaskets.
  9. Tighten the valve cover bolts to 11 ft. lbs. (15 Nm) in a crisscross pattern.
  10. Install all necessary electrical and vacuum connections.
  11. Install the air cleaner assembly.
  12. Install the A/C bracket (if removed).
  13. Install the A/C compressor and belt (if removed).
  14. Connect the negative battery cable.
  15. Start the engine and check for leaks.
2.3L and 2.4L 5-Cylinder, and 2.9L 6-Cylinder Engines The 2.3L and 2.4L 5-cylinder, and 2.9L 6-cylinder engines have a two-piece cylinder head, the upper half and the lower half. The upper half is basically the same as a valve cover, except that it incorporates the bearing caps for the camshafts into the underside.
  2. Remove the spark plug access cover.
  3. Label and remove the ignition coils and vent hoses or the distributor cap and wires if equipped.
  4. Check the cam alignment before removing the cylinder head.
  5. Remove the bolts attaching the upper cylinder head.
  6. Remove the upper cylinder head, lightly tap with a soft hammer if necessary. To install:
  7. Thoroughly clean the upper and lower cylinder head gasket mating surfaces.
  8. Apply liquid sealing compound to the upper cylinder head mating surface. WARNING
    Use a roller or your finger to spread sealant, do not use an excessive amount of sealant, or the oil passages could become clogged.
  9. Place the upper cylinder head onto the lower cylinder head.
  10. Check the cam alignment before tightening the cylinder head.
  11. Install Volvo tool number 5454 or equivalent to the upper cylinder head.
  12. Tighten the nut on the tools to seat the upper cylinder head.
  13. Tighten the upper cylinder head bolts, beginning from the center out to 13 ft. lbs. (17 Nm).
  14. Install the ignition coils and hoses or the distributor cap and wires.
  15. Install the spark plug access cover.
  16. Connect the negative battery cable.
  17. Start the vehicle and check for leaks. Fig. 2: Remove the clamp and detach the vent hose 90953p66.jpg
    Fig. 3: Remove the spark plug cover and the plug wires or ignition coils to access the retaining bolts 90953p80.jpg
    Fig. 4: Remove the retaining bolts 90953p72.jpg
    Fig. 5: A light tap with a soft-faced hammer is usually required to loosen the valve cover 90953p81.jpg
    Fig. 6: Carefully lift the upper cylinder head up and off the lower section. Note the integral camshaft bearing caps in the casting 90953p82.jpg
Jan 29, 2011 | 1999 Volvo S70
Our Blanco Cleo 6100 Cruciform Monobloc tap is dripping & I think it has a ceramic disc valve as opposed to the more common tap washer. Is it possible to replace the ceramic valve & if so...
The tap is a Blanco Cleo BM/6100 tap.
The cost for a pair of valves is £41.51 including postage and VAT, the cost for one is £25.97.
Scott Lindley
Blanco Customer Service Manager
Top Brassware Ltd
T- 01709 819077
F- 01709 798888
Top Brassware Ltd
Unit 3E Aven Industrial Park
Tickhill Road
S66 7QR
Jan 07, 2011 | Microwave Ovens
How do you remove the hot and cold taps on a shannon monobloc mixer tap, water is dripping from the cold tap
Use 2 Adjustable Wrenches . you may need a Allen key set to Remove the Mixer unit . You can fix the Water dripping problem may be replacing a O ring
Nov 18, 2010 | Plumbing
On the back of the mixer tap on my astracast sink has a small hole that seems to be part of th mixer tap is leaking when the cold water is on and not the hot, can you help?
I sounds like the cold side of the faucet has a bad side. Contact them for free parts for that side and directions on how to install. It could be just those rubber seals but my be the actuator for the cold water.
Oct 06, 2010 | Astracast ACR1919MB Rok Composite Kitchen...
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
Oil pump replacement
This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
  1. To remove the relief valve, proceed as follows:
  2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
  1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
  2. Remove oil pump cover screws, and lift off cover.
  3. Remove pump rotors.
  1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
Oil Pump Assembly
  1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
  2. Tighten cover screws to 12 Nm (105 inch lbs.).
  3. Prime oil pump before installation by filling rotor cavity with engine oil.
  4. Install chain case cover. Refer to Timing Chain Cover Installation.
REMOVAL of Timing cover
  1. Disconnect negative cable from battery.
  2. Remove timing chain cover.
REMOVAL Of Oil Pan to gain Access to OIL PUMP
  1. Disconnect negative cable from battery and remove engine oil dipstick.
  2. Raise vehicle on hoist and drain engine oil.
  3. Remove bending brace to transaxle attaching bolt.
  4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
  5. Remove oil pan screws and remove oil pan.
  1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
    1. Use a new pan gasket.
    2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
    3. Install dust shield and bending brace to transaxle housing.
    4. Lower vehicle and install oil dipstick.
    5. Connect negative cable to battery.
    6. Fill crankcase with oil to proper level.
Mar 27, 2009 | 1998 Chrysler Town & Country
Fitting monobloc kitchen diagram on pipe fittings
The tap should have 2 pipes about 6-10 inches long and almost the thickness of a maker pen {10mm or 15mm]
U will need either a 10-15 connection or a 15-15 connection either straight or elbowed according to routing need to main pipes [& these should also be 15mm
connections are fixed either with solder or have nuts on each end to tighten [compression] or are just push-on ["Speedfit"]
Ger back if u need more
Mar 23, 2009 | Plumbing
Plumbing Logo
757 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
