Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
I have a monitor 22 running on the save line 70 feet from the oil tank that runs okay. Monitor 15 feet away is showing out of fuel. Oil tank is in garage. Temperature is 14 below zero. Clean filter on monitor plenty of fuel did not run. Disconnect fuel line from hub no fuel comming out after starting monitor. Temperature is 10 degrees monitor is okay. Changed filter on oil tank. Ran okay for 12 hrs. went to bed. 5:30 AM Temperature 0 degrees monitor out of fuel. Is this problem with flow of fuel or the monitor?
  • 2 more comments
  • Thomas Hawkins May 11, 2010
    Rolo, When you say the Monitor shows out of fuel, exactly what do you mean? What model stove is it that is giving you trouble and how long have you had it? Thanks, Tom
    Rolo,
    Did you freeze to death or did you get the Monitor going? We are dying to know here.
    Tom Hawkins
  • Scott Magill May 11, 2010
    Have you checked pressure at heater to make sure it has pressure or it could be air locked.Not really sure what you are asking can you tell me a little more information on what is going on. does the rinnai try to light
    Rolo,
    How did you determine the stove was "out of fuel"? The light bars flash anytime the stoves quits for any reason. We need more info.
    Try the stove and listen around the lower right side of the unit until the cycle is complete. If you hear a bumping noise just before it stops you have a fuel problem. NO bumping and a flame, you have other problems. Keep us posted
    Tom Hawkins
    hawkins111@gci.net
  • 674 Answers
Hope you got this fixed. Sounds like you were having fuel flow problem.
Posted on Feb 13, 2010
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Need to drain fuel tank
Okay, this is going to sound a bit different but it works. It is simple and will remove most of the gasoline with the least effort.
Go online and look up the fuel pump Relay and "jumping" this Relay for your year and model car. I did this for my 2002 Grand Marquis and removed about 16 gallons in about 15 minutes. Remove the fuel pump Relay and put a decent gauge wire in the #27 and #34 terminals in the Powerbox only when you want to pump out the gas. Verify these 2 terminals with the article about jumping a Relay. This will cause the fuel pump to run continuously, use only when ready.
You will need a Tire valve stem removal tool and a length of rubber fuel line(4-5 feet) about 1/4 to 5/16 inner diameter. On the Drivers side of the fuel rail there is a test port. It has a valve similar to a tire stem. Remove the valve core. Insert the fuel line over this test port and secure with a small hose clamp.
Have a fuel container ready to pump fuel into. In a well ventilated area you are now ready to pump fuel.
Since the fuel tank has baffles there is little way to drain the tank without dropping the tank and turning in a way to allow for the fuel to run out.
Even disconnecting the disposable fuel filter is not without complications and you would still need to trigger the fuel pump. So for the expense of rubber hose and a valve stem tool the above method is easier.
Dec 27, 2013 | 2002 Ford Crown Victoria
Suzuki 50 moped ran out of fuel
Hi, Dawn if you have an old bike that has not had regular fuel system maintenance and you run the fuel tank dry I feel your pain. All the contaminants water-dirt-rust-liner paint flakes-ethanol sludge etc. that lived in the bottom of your fuel tank get mixed with the last few oz. of fuel left in the tank and enter the fuel system clogging up fuel filters-fuel valves-fuel lines-carburetor jets-needle jets and seats-fuel injectors etc. You fill up your fuel tank and guess what your bike does not start or if it does it runs poorly, a complete cleaning of the fuel system is mandatory, the procedure is as follows:
1. Drain the fuel tank and inspect the inside for leftover uninvited guests decontaminate as necessary for rusty environments install a liquid fuel tank liner.
2. In tank fuel pumps with external filters need to be cleaned.
3. Fuel valves need to be rebuilt with a new gasket kit.
4. Fuel lines need to be inspected for integrity and replaced as necessary any inline fuel filter should be cleaned or replaced.
5. Carburetors need to be disassembled then "DIPPED" and soaked in a commercial carb cleaning solution Gunk sells 1/2 gallon pails with meshed screen baskets. Reassemble using new rebuild kits. Record all jet sizes and float level for fine-tuning.
6. Fuel injectors and fuel rails need to be properly cleaned and tested for optimum performance, if necessary send off any suspect injectors to "InjectorRx.com" for a modest fee they will refurbish the unit back to factory specs.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Ran out of gas now it won start
Ran out of gas won start Suzuki Savage 1995 motorcycles
Suzuki FA50 Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
Suzuki FA50 Owner Manual
Dec 02, 2017 | Suzuki Motorcycles
1983 kawaski kz100 spectre high idle to keep running
Have you cleaned the tank, fuel can cause steel to rust, drain carbs and blow the jets out. Then make sure you change (or fit) the in line fuel filter, they are cheap and easy to replace and save problems like this.
Dec 17, 2011 | Motorcycles
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Mar 29, 2009 | Garden
I have an 81 Toyota Celica 22R and I started having problems with the car. The Carb was already rebuilt about 6 years ago. I have never had a problem with it before now. It has a rough idle that comes and...
Try running a Can or two of B12 Chemtool through the Fuel system with a Full tank of gas. 1 can per tank. Usually works for me. This will clean the Injectors, Jets, Valves, and ANY Carbon buildup anywhere in there.
Jan 12, 2009 | 1987 Toyota Pickup
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
328 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
