Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
I have one thermostat for 4 electric baseboard heaters all in seperate rooms, i want to disconnect one of them how do I do it?
    Novelist:
  • 88 Answers
You have to shut the power off to all your baseboards, make absolutely sure that the power is off !!!!! once you are sure, then its a matter of unscrewing the unit from the wall, then opening up the panel, uncouple the wires inside the unit that supply the power, wire nut the wires then tape with electrical tape, if at all possible remove the power leads from the breaker panel that feeds that particular baseboard, if not, then make extra sure you have the power leads secure and taped off as so they will not touch together or anything else, I would strongly recommend that you hire a certified electrician to do this !! as this type of home repair is very dangerous and deadly. hope that was helpful
Posted on Jan 20, 2009
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
100 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
