Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Window screen problem
My monitor is SyncMaster 226BW, Samsung. If the resolution was set at less than the maximum, the window screen stayed at the center of the monitor screen and takes only a half or 2/3 of the monitor. I tried to use the monitor adjusting buttons to change the size of the window screen, it didn't work. If the Pixel was set at 1680x1050, fonts of other programs are very small and all the websites are presenting on the half of the screen. Please help me with this problem. Thanks.
  • 432 Answers
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
Posted on Jun 22, 2007
SOURCE:
How to change monitor resolution
You change the resolution using your windows operating system.
If you are using a window computer press the start Button lower left end corner of your monitor screen and select control panel then select the resolution option or screen display depending on the version of windows you are using.
Mar 24, 2012 | Samsung SyncMaster 750S Monitor
Maximum resolution for my Samsung 740NW is now 800 X 600. Can this be increased to at least 1240 X 600? My system is Windows XP professional.
Your monitor can reportedly display a maximum resolution of 1280 x 720. The resolution your graphics card is outputting can be changed in your graphics card's resolution settings.
Jun 05, 2011 | Samsung SyncMaster 740NW
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 07, 2010 | Samsung 226BW Monitor
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Hi, I cannot get my syncmaster to show the whole screen of my laptop
What is the current screen-resolution of your laptop, e.g., 1280-by-1024?
What is the maximum resolution of your LCD screen?
If it is "less" than the laptop's resolution,
part of the picture will be "off-screen".
Reduce the screen-resolution of your laptop to match the maximum resolution of the LCD.
Nov 23, 2009 | Samsung SyncMaster 205BW LCD Monitor
I have a samsung syncmaster 915a which resets to max resolution. Can I change their Motherboard equivelint??
Resolution is determined by the display settings, up to the limits of the hardware. In windows, if you right-click on your desktop and select settings, click the "display settings" tab on the resulting window, you can select lower resolutions (icons etc. get bigger, less stuff fits on screen) if you desire. Be sure to click "apply"
Nov 15, 2009 | Computers & Internet
Samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Aug 27, 2009 | Samsung 226BW Monitor
My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
May 23, 2008 | Computers & Internet
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Samsung 226BW Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
281 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
