Question about Adaptec 3.5" USB 2.0/Firewire Combo Hard Drive Enclosure Drive Cabinet 1 x 3.5" Internal (2188800FT) Drive Case
Adaptec external HD will not be recognized
I have a Eee PC that has LINUX as the OS and it will not recognize the HD when it is plugged into the USB port. Is there a driver that will allow the LINUX OS to recognize this drive
2 Suggested Answers
Fredinot
  • 96 Answers
SOURCE: Adaptec ACS 100 USB 2 external case suddenly USB 1
Please use a fix disk program to solve this problem.
Posted on Jan 28, 2010
Computer does not recognize external drive
Have you tried connecting it to different USB ports? Sometimes it works on one but not on another.
Does the drive needs an external power supply? Some models do, others works just by plugging them on USB directly - check your manual for this one.
Does the drive works on another computer? Test it to see if the problem isn't the drive itself.
Have you tried it on another OS? (You can download and burn a Linux Live-CD or even run it from a USB stick: http://www.ubuntu.com/download/desktop) - If it works on this, but not on your regular OS, may be a driver problem.
Does the drive needs drivers? If so (it's unlikely), you should install them.
If all fails (drive doesn't get recognized on another computer, doesn't use external power, doesn't work with other OS, doesn't need drivers) then the driver may be at fault, and you should return it.
Nov 05, 2013 | Maxtor Personal Storage 3200 (U01E200) 200...
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
Jun 20, 2011 | Seagate 160GB 3.5" External USB Drive 160...
Is it possible to connect a web cam on my asus eee pc 2g PC notebook running on linux ?
yes, for as long as linux supports USB connector platform. Although they are different OS, they have the same basic concept of recognizing the USB port into your system...
Feb 11, 2011 | ASUS Eee 2G Surf Notebook
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
My pc doesn't recognize my verbatim 1000gb external hard drive, error "unknown device"
Did the 1000gb external hd come with instructions?
Did you read them?
Did you Install The Software for this Device?
If not. Try plugging it in all the usb ports.
Try shutting down the PC, when it's off plug in the 1000gb external HD,
Restart the Computer, If Windows still dosen't recognize it, then it's most likely defective, and should be returned. Try purchasing a higher quality brand.
Nov 20, 2009 | Verbatim VER95327 USB Hard Drive
Re: the Asus Eee PC 900 Notebook with a Linux operating system and am unable to connect. It will detect my wireless router (Cradlepoint MBR1000 using Verizon USB720). I upgraded to the Verizon USB 760...
what version of linux are you using? If it's one that came preinstalled with the laptop I suggest looking at Ubuntu netbook edition, *very* capable OS, if that can't handle it nothing will.
Aug 02, 2009 | ASUS Eee PC 900 PC Notebook
Eee pc does not recognize ipod touch when conected to usb port
Connect the usb be port and restart the laptop that will do
Mar 23, 2009 | ASUS Eee 4G Notebook
Loading OS
Cannot boot from External device
Check out this link. This should resolve your issue.
Regards
Aug 30, 2008 | Toshiba Portege 3500 Tablet PC
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Computers & Internet Logo
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Timothy Van Der...
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
