Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How can I print off my Epson DX7450 using the balck ink cartridge
I have a DX7450 printer -
I would very much appreciate it if I could be advised as to how to print off my documents using the black ink cartridge only. Up to now I have to keep replacing the colour ink cartridges, in order to just print off documents in Black ink only - this does not seem right or to make sense?
Thank you for your assistance with the above problem.
Suzie
  • bappus Jan 29, 2009
    Exactly the same problem with me...despite changing Printer Preferences in the Control Panel to Black Ink Only, Epson's software overrides this and insists I top up my coloured cartridges, even though I only want to print out a b&w document and have plenty of black ink left! Extremely frustrating!
5 Suggested Answers
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
hokuwho
  • 306 Answers
SOURCE: Epson 1290 (Suzie Tisch)
Try printing a test page by going to Start>Control Panel>Printers then select the printer, right click for Properties and click on Print test page. Inspect for all colors. If all colors are present then check the resolution settings. Which application are you printing from?
Posted on Oct 21, 2008
gwbm
  • 353 Answers
SOURCE: EPSON PRINTERS how to replace inks in epson DX 7450
You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
Posted on Nov 28, 2008
SOURCE: don't know how to move the cartridges to replace the ink.
i need to replace ink cartridges on a epson dx7450. Can anyone help?
Posted on Feb 22, 2009
  • 2692 Answers
SOURCE: Epson DX8400: how can i get it to print black only
Sorry Desperate. All inkjet printers, from all companies,  are programed to only operate with ink in all containers to avoid other problems. Their is no workaround. Please rate me not harshly just  because you don't like the answer. Rate based upon the truth of an answer.
Posted on Mar 11, 2009
How do i change a cartridge for epson printer DX7450
Click on yhe following limk to see the online manual
Click to open the manual. Click on the Printing. Under this title you will see about ink cartridges.
Hope this will work for you.
If it is helpful. give a rating.
luciana44
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX7450/Drivers-Support
Jan 09, 2010 | Epson Office Equipment & Supplies
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Epsom printer dx7450
    you could have one of several problems here.
    i,d suggest printing several test pages, and observe whether the red comes through after this.
    if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
    finally if you have the original software installed for the printer, try a head cleaning operation.
    Mike @ Compurepair.
    Jun 22, 2008 | Epson Stylus C60 InkJet Printer
    Jun 13, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
    Epson DX7450
    use hiest quilty option ok not draft or normal least 1 step above normal printer use more ink better prints ok
    Mar 13, 2008 | Computers & Internet
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    1,084 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
