Question about Toys
Butterscotches tail has been broken off how can I fix it
The white plastic spindle has broken off
    Problem Solver:
  • 15 Answers
Call the company, ask them what they can do for you.
Posted on Jan 17, 2009
How to get into and fix tail doesnt move anymore
Here is a link to instructions for removing the fur from the FurReal Friends Butterscotch Pony. Beyond that, I have no idea how to fix a broken tail. If you can find somebody who works on robotic/animatronic toys, or a good handyman, they can probably fix it for you.
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/?ALLSTEPS
Dec 22, 2011 | Hasbro Fur Real Friends Smores Pony
How to fix a broken tail
Call Hasbro Customer Service / Replacement Parts. Hasbro is out of stock on A LOT of stuff, especially the extras like carrots and brushes, but they may be able to send a replacement tail. If you have the tail and can see the break, it may be possible to fix, but you'll need a plastic:plastic epoxy (I can recommend). Do you have pictures? You can contact Hasbro CS directly at 1-800-327-8264 :)
Dec 01, 2011 | Hasbro Furreal Friends Butterscotch Pony
The tail broke on my butterscotch pony and I would like it fixed. What can I do? Thanks
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
May 25, 2010 | Hasbro Fur Real Friends Smores Pony
Replacement parts
Not sure about the ear but here is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
May 09, 2010 | Hasbro Fur Real Friends Smores Pony
Hi, Where can I buy a new tail for my daughter's Butterscotch pony Furreal Thanks Michelle
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Apr 18, 2010 | Hasbro Fur Real Friends Smores Pony
My daughter has broken the tail off. Can we
Feb 07, 2010 | Hasbro Furreal Friends Butterscotch Pony
We bought our daughter a butterscotch pony last year for christmas but she hs now pulled the tail off. Can we can a replacement tail?
Dec 09, 2009 | Hasbro Furreal Friends Butterscotch Pony
Looking to repair the tail on Butterscotch pony
Dec 01, 2009 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony snapped tail
Nov 12, 2009 | Hasbro Furreal Friends Butterscotch Pony
Buterscotch poney replacement tail
Oct 21, 2008 | Toys
Toys Logo
236 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
