Knob does not move
Does the control Knob turn from the programme No to the end of the cycle or does it stay still ? I select a programme say h the machine washes and rinces but does not spin and empty?
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Whirlpool awo/5556 programme knob displays wrong timing for wash cycle
Answered earlier , suspect this error can be due to internal clocking of the program controller unit.
Mar 12, 2012 | Whirlpool Washing Machines
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Sep 18, 2010 | Washing Machines
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Mid cycle stop
the thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
Feb 12, 2008 | Asko D1716 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
