Question about Sony KV-20FS12 20" TV
Please, Help me fix my TV
When I turned the TV on, then the picture start blinking each 5 secunds, just the video get off end get on, the high voltage still that. I increase the screen voltage to see the picture on when the video turn off, Yes the screen stoll on. Please sumbody know fix this problem? Thank you for you help. I'm sorry for mi English
  • Anonymous Jul 02, 2007
    Thank you Scrivitron for your help. I replaced that resistor with one 2.2 homs, then the tv get better, then I put back that original reisistor, and I rejuvenated the picture tube, the video get perfect. Thank you so much. I'm sory for my English.
    Scholar:
  • 47 Answers
It sound like you have abad picture tube. Iknow this is not the answer that you want to hear. Sony's have video blanking circuit built into the video processor(in the jungle IC) when the emission of all three gun fall out of an acceptaable range. the screen blinks and when you turn the screen control on the IHVT all you see is re-trace. Some times there is a current limiting resistor in series with on lead of the heater on the crt board. By changing this resistor from 2.2 ohm to >.1 ohm @1/2 watt you can sometimes increse the filament voltage to the point that the blanking stops. This is only a temporary cure not a fix. The picture tube is probably bad. Scrivitron
Posted on Jun 21, 2007
SOURCE:
RED FLASHING LIGHT
sir
these are the causes for 5 red blink in your modal
Video OUT (IC1545) is
faulty. (A board)
• IC001 is faulty. (A board)
• Screen (G2) is improperly adjusted
thanks
Oct 03, 2017 | Sony Televison & Video
When i turn on my tv the sound comes on and about the time the picture would come on the whole tv shuts off and then the standby light blinks 5 time between pauses
5 blinks error means that there has been a white balance error triggered either due to faulty video ICs on either of the CRT boards or the CRT drive IC on the A-board is faulty. I do have the service manual and can help you fix it if you know how to use a multimeter and solder. I should also tell you that this is high voltage electronic device(especially the near the CRT boards). The CRTs act as giant capacitors and hold voltages of upto 30,000V for several days after the set has been unplugged. I did not mean to scare you but I just wanted to give you a headsup!
May 28, 2011 | Sony KP-46WT520 46" Rear Projection...
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Screen will not light up.standby/timer light blinks continuosly
check for any cold solder on the high voltage section of your tv A high voltage section is located at the power supply section, this is where the power cord is connected.resolder them,the horizontal section it is where the plyback transformer is located resolder them and the CRT board this is the boad that is attatched to the picture tube...good luck
please rate my help..
Jun 04, 2010 | Sony KV-35S42 35" TV
TV shuts itself off..red light blinks 7 times.
The 7 blinks usually indicates a high voltage shutdown situation. Without the specific model, I can;t give you details about parts etc. The options are a defective flyback transformer or problem with the voltage regulation circuits. Please update this with the model number and I'll post additional details as soon as I can.
Thanks,
Dan
Jan 30, 2009 | Televison & Video
I have a Sony Wega tv, my problem is that when you turn the TV on...it turns on for like 5 sec. only hear the sound at that point, no picture yet...then it shuts off. The red light on the front pannel...
The 7 blinks usually indicates a high voltage shutdown situation. Without the specific model, I can;t give you details about parts etc. The options are a defective flyback transformer or problem with the voltage regulation circuits. Please update this with the model number and I'll post additional details.
Thanks,
Dan
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
No picture
The power supply or sweep power supply blew up, or the Horizontal/high voltage circuit went bad. If you have no tV repair experience, call in a pro to assist you in this repair. Good Luck
Mar 31, 2007 | Sony KP-51WS510 51" Rear Projection...
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Sony KV-20FS12 20" TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
