Question about MagLite Mag-Lite& Flashlight
Batteries stuck in torch
I have a 4 cell maglite and the batteries leaked and are stuck inside. Do you have any agents in South Africa that could repair this for me,
Regards
Clive Godfrey
  • heathbar2009 May 15, 2009
    the batteries leaked and I can't get them out. How do I get them out since they are stuck.
I had the same problem same mag lite.
After removing the lamp ect I soaked the barrel and batteries in WD40 for a few days. Using a soft faced mallet hold the torch in one hand and few sharp blows later the battery was dislodged. I must admit there was not a great deal of corrosion though. I then cleaned out the barrel by wrapping Carborundum paper around a broom handle inserting it into the barrel and just reamed out the barrel cleaned all the swarf out with tissue on the stick sprayed a drop of the WD40 into the barrel and its worked a treat ever since.
Regards
Posted on Feb 09, 2009
Hi Clive
Ramrod Manufacturing (PTY) Ltd
47 Staal Street
KYA Sand
Randburg. South Africa
Telephone 27-11-462-6986
Are listed on the maglite website as repairers in South Africa.
Posted on Jan 18, 2009
I have a c cell battery stuck inside
Try tapping the base of the (battery opening) torch on a hard surface so the battery can slide out.
Jan 22, 2012 | MagLite 4 Cell C Flashlight Black
Got a a six cell Mag Lite D and the batteries have corroded and jammed inside.Got 1 out, 5 stuck fast. How do I get the damn things out!
The bad news is, the torch will likely not work even if you could remove them which is unlikely. The acid will have rotted the business end of the torch terminals. Time to throw it in the bin my friend.
Dec 19, 2010 | MagLite Mag-Lite& Largehead Flashlight
Can't open the flash light to change the batteries? Does the bottom open up? Do the batteries get replaced from the top by removing the bulb first?
The back, tail cap, should be unscrewed from the maglite to replace the batteries. It can be pretty hard to open as they are generally not opened very often and there's a rubber seal to keep it water-proof. You could try using a pliers or vice but be careful not to squeeze it out of shape.
There's also a possibility that if the batteries are in it a long time that they have leaked and the leaked chemicals have sealed it. If this is the case you may be able to get the maglite replaced depending on what brand of batteries were in it. Maglite have an agreement with the makers of Duracell, Ever-Ready and Ray-O-Vac to replace the Maglite if one of their batteries leak in it.
Details are on the bottom of page at http://www.maglite.com/faq_details.asp?faqProd=C
Nov 01, 2010 | MagLite 4 Cell C Flashlight Black
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have a mini maglite - and I cannot remove the batteries. For the price, these certainly can't be disposable lights! Only the narrow end of the light can be removed, the bulb end does not enable you to...
Try tapping the base of the torch gently on a table, this may dislodge the batteries . Possibly the batteries leaked and corroded and became wedged in the torch ?
Aug 05, 2010 | Garden
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
A cell (Duracell D) has got stuck in the barrell of my 3 D cell torch. All efforts to pry it loose with a sharp intrument have failed.
Most likely the Duracell Battery in there is corroded and had fused itself to the inner aluminum wall of the light. MagLite warranties their flashlight if damage from a battery was caused by either a Duracell, Ever-ready or Ray-O-Vac battery. Same thing happened to me, I brought it to their Repair Center in Ontario, CA and they tried to remove the battery while I waited, they couldn't remove it so the gave me a brand new flashlight. They are real good about backing up their product. www.maglite.com You can call them at
back_hd_feedback.gif CONTACT INFORMATION Corporate Office
MAG Instrument, Inc.
2001 South Hellman Avenue
P.O. Box 50600
Ontario, California 91761 U.S.A.
Business Hours:
Monday - Friday 8:00 a.m.- 5:00 p.m. Pacific Time
Sales & Parts: Phone
Fax
909 947-1006
909 947-3116
Corporate Gift Sales: Phone
Fax
909 947-1006
909 947 3056
Warranty / Service Address: MAG Instrument, Inc.
1721 East Locust Street - 51453
Ontario, California 91761-7769
Warranty Business Hours: Monday - Friday 7:00 a.m. - 4:30 p.m. Pacific Time Warranty: Phone
Fax
909 947-1006
909 947-5041
May 17, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
Batterys stuck in a maglite flashlight
Ok, problem is the acid has corroded and caused a white powder residue to form, you will have to spray a solvent into the torch to free the batteries... bad news? the corrosion cannot be fully cleared and the maglite will always be on the blink... sorry but i have tried several times for people and just cannot clear it out fiully
Mar 24, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
How do I get swelled and leaking battery's out? of my 4 D cell mag light, the one on the end came out but the next one is stuck. I tried a few drop of vinegar to neutralze and thin the alkalie goo,...
I found some info on this site...
http://cr4.globalspec.com/thread/14899/Leaking-battery-stuck-in-Mag-Lite#comment150608
"Sadly, when a dry cell leaks, the leaking chemicals react with the torch casing, as you have noted.
With all Maglite torches I have ever seen, you can remove both ends of the cylinder which encloses the batteries.
In this situation, get a broom handle or wooden dowel, just a bit smaller than the torch battery diameter, and after soaking the cylinder/switch assembly cylinder in hot water (boiling if you can) for an hour or two, give that inserted dowel a few taps with a large hammer or mallet.
Normally the leaking battery comes out easily, providing you let it soak in hot water long enough to soften the corrosion products.
Once you have gotten out that battery, leave cylinder soaking overnight, and use an old toothbrush to remove the last of the oxide etc , and allow to dry thoroughly.
As a tip for next time - to save you all this bother: Oil or grease the inside of the torch cylinder, and re-coat with oil (silicone grease is best), each time you replace batteries.....smiley-cool.gif"
hope this helps you.
Jan 19, 2010 | MagLite Camping, Backpacking & Hiking
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
MagLite Mag-Lite& Flashlight Logo
1,025 people viewed this question
Top MagLite Electrical Supplies Experts
Karl Kittsteiner
Judi McInnes
Level 1 Expert
lakeareaserv
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
