Question about Kenmore 46462 Front Load Washer
All cycle indicator lights are ON !!
All of the cycle indicator lights are ON after the washing circle. It does not go to the next spining step. I unplugged the machine and waited, powered it back on to "drain and spin" since It stopped the rinse and spin cycle before it was done. Still all lights are blinking Any help ? Thanks
  • Laz Mir Jul 16, 2007
    Hi:
    Thanks for your comments but I found the solution.
    I removed the front cover (three screws at front). There you could see the main pipe drain line(WHITE). Just open that drain and by surprise a pair of sox from my little kid. It was blocking the rinse and draining circle. I wonder how it when thru. No more issues so far.
    Hope it can helps others
    Regards
    LM
  • Anonymous Dec 21, 2007
    We had the same problem with our wash machine and we unscrewed the three screws on the bottom panel and unscrewed the white drain tube and found three color catcher in there (don't use those things they get in thur the rubber and then into the drain tube). Thanks for the good advice you saved us a service charge.
Your solutions were perfect, it had 3 dollars in coins and safety pins sitting in the tray. Just a note, before you unscrew the white tup, get a bowl, becasue you may have a large aomunt of water. thanks again save me a call to the repair man and then have to sit betwwen 9-5 for him/her to show.
Posted on Aug 24, 2008
    President:
  • 1,294 Answers
Frecklpwr & daniellemk should at least have clicked on the Fixya color blue!!..........they were getting their probs solved thru someone's intelligent input..........really sad.
Posted on Nov 30, 2007
Thank you so much!I logged on to see if anyone knew what a ccertain error code meant and found this solution which fixed my problem!You saved me a call to Sears and what I am sure would have been an expensive house call!
Posted on Oct 12, 2007
I had the same exact problem and your post solved it completely! Thanks for saving me lots of $$$ by not having to call the service repair guy. Cleaning the trap and removing a child's sock did the trick.
Posted on Sep 03, 2007
Hi there - yes! we did have the problem fixed. Thankfully, we were still under warranty and the machine needed a new COMPUTER in it!!! can you believe it? it didn't cost us anything since we were still under warranty. and the service guy said this happens pretty often. so, I'd say, hurry up and call before your warranty runs out, good luck!
Posted on Jul 14, 2007
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
On spine cycle washer thrashes around, hard thumps
Your load is probably unbalanced. Open and redistribute the garments or take some items out.
Mar 08, 2010 | Bosch WFMC 3200 Front Load Washer
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Spin cycle
hold cancel for 10 secs
hold end of cycle signal 10 secs.
one of them should reset it.
Feb 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Kenmore 46462 Front Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
