Question about Sony VAIO GRX550 Notebook
Hard disk not detected in bios - Sony VAIO GRX550 Notebook
Check the hard disk power and the cord either the hard disk is faulty or the cord
Posted on Jan 17, 2009
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
I cant formate my c drive with bootble dvd or cd
The hard drive may be faulty.
Go into the BIOS setting and see if the BIOS detects the hard disk, if not reseat the hard drive and if the BIOS still does not detect the hard disk then the hard disk is faulty.
Nov 30, 2011 | Seagate HDD Computers & Internet
Bios cannot detect hard drive suddenly. I was running the PC well. Trying to start the PC again, cannot go into windows. Check on the bios, no hard drive detect.
Follow the steps given below.
1) First, check your hard disk cable, I recommend you to replace the Hard Disk Cable.
2) If the BIOS doesn't detect your Hard Disk after replacing Hard Disk cable try upgrading your BIOS from the Dell website.
Jul 06, 2011 | Dell Studio Xps 9100 Desktop Computer
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
My dell latitude says no bootabble devices and no drive what should I do to fix this
Dear sir...
3.remove the battery first,then press the on/off button 20 seconds.then replace the battery.
--------------------------------------------------------------- Check the hard disk is detected in the BIOS(follow the below steps)
1.on the laptop,immediately press Del. (F2 or Del or F10 these are common to display the BIOS setting)
2.Check the menus one by one whether the hard disk is detected or Not detected.
if the hard disk is not detected then remove the battery,remove and replace the hard disk .(See the laptop manual) -------------------------------------------------------------------------
if the hard disk is detected then set the BIOS with Basic Default configuration.
press F10 Press Y Press "Enter"
All the Best sir... Thank you........
May 16, 2010 | Dell Latitude C510 Notebook
Bios not find hard disk
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 24, 2009 | Acer TravelMate 2303LCi Notebook
My computer stopped suddenly and did not detect hard disk
restart your cmos by removing the battery on your motherboard and if that doesn't work update your bios.
Dec 20, 2008 | Intel D845GVSR Motherboard
I shut my laptop and next time i tried to switch on, it say operating system not found
your hard disk is not detected in bios setup.
for ente rin bios press del or F2 or enter for enter in bios.
thenn check in ide configuration yoour hard disk is detected.
then go to boot option set your hard disk as first boot device there.thne save settings.
then check.
if problem occurs then reset all defauls settings of bios but first try to detect your hard disk.
Nov 27, 2008 | IBM ThinkPad T20 2647 Notebook
Sony VAIO GRX550 Notebook Logo
158 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
