Question about Whirlpool AWM5125/1 Front Load Washer
Awm 5125 front load
My machine will not spin between prog 10 and A this is fast spin sounds like its trying to but dies also water left in drum at the bottom
I had the same problem tonight!! I opened the filter at the front and found one of my baby sons socks and 81 cents!
The machine is draining away perfectly now, but the floor got soaked when I opened it, so be prepared.
Hope this helps...
Posted on Jan 18, 2009
I have a wma 10 which is a couple of years old. The door seal now leaks when the machine goes onto a spin? Is there anything that you can suggest?
Sounds like there is too much water left in the drum as it goes into the spin cycle, and the centrifugal force of the drum spinning is forcing the wate past the door seal probably, needs the filter cleaning, or the door seal itself may require replacing.
Aug 04, 2010 | Hotpoint First Edition WMA12 Front Load...
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
WHIRLPOOL 5125 LOUND NOISE
I take it you are refering to the AWM5125
The sound you hear are the bearings on their way out. You will need a replacement rear tub half
Jan 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
Awm 5125 front load womt spin
Check the agitator(the big plastic piece in the center)you can remove the cap in the top and there will be a bolt that holds it on,remove the bolt and see if the plastic gears are worn out.
Please rate this solution
Jan 20, 2009 | Whirlpool AWM5125/1 Front Load Washer
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
