Question about Kenwood KD-291RC Turntable
Turn table on hifi does not turn what is the problem
Went to play a record,turn table would not turn
Turntables are belt driven..... the belt could have snapped or come off.......
Posted on Jan 17, 2009
Technics sl-b35 shut off not working. What should I look at? Record play, arm returns, but will not shut off.
This could be a mechanical switch that is stuck in play mode. You might have to take the bottom off the deck to see what is happening inside.
Feb 08, 2015 | Technics Audio Players & Recorders
Got a panasonic compact audio system model # SG-HM09A the turntable plays the record fast
there should be a small switch on the inside of the turn table that allows you to switch from 45 (what i think your listening to) to the normal speed which i think is 33
Jan 25, 2013 | Panasonic Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
I accidentally turned off the player while a record was playing. Now when I try to play a record, the needle will hover over the record but the turn table will not turn. Any idea on what the problem is and...
The turntable has to go back to its reset position ( Or Start position ). Turn the platter with your hand while the system is on and see if you can get a light click after some revolutions.If so you have rest the system and should play. Or else lift the rubber Matt and see if the belt is still wrapped round the platter. Rotate the platter while you are doing it and at one point you will see the pulley of the motor and the belt very clearly. If its fallen off put the belt back on.
Mar 08, 2011 | Spectra SB6053 Turntable
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Seal Turntable - lousy recording!
HELLO
These cheaply-made turntables only do ONE job and that is to archive your record collection. Not surprised by the fact the record plays great on your normal turntable.
The arms on these turntables have quite a heavy tracking weight to them and you cannot adjust it. My advice to you is if you want to archive vinyl there are plenty of quality HIFI turntables out there that will blow away your Seal turntable. Don't be tempted to put a small coin on the headshell as this will INCREASE the weight and probably damage your record.
A friend of mine has one these awful Seal tables and I think they are pretty bad sound quality, also they go under many different brand names.
AVOID!
May 10, 2010 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Juke box will take coins but won't play record
WHAT IS THE POSITION OF THE GRIPPER ARM(CALLED GRIPPER ARM THAT GRABS RECORD?)
OVER THE TOP OF THE 50 RECORDS? NEAR THE TURN TABLE?
IS THE OPERATE SWITCH IN PLAY POSITION ? OFF POSITION ?
DOCTOR FIX.
May 09, 2009 | Audio Players & Recorders
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
Kenwood Turn table
And play then at the same time.....those stopped being produced for the consumer market since the 90s. You will need to find a manufacterer still making automatic turntables..start from there, those those turntables usually are hard on records and offer poor fidelity.
Oct 03, 2007 | Kenwood KD-291RC Turntable
Kenwood KD-291RC Turntable Logo
123 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
sonic boom...
sonic boom...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
