Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung 46" DLP
TV has no picture but does have sound until all three lights start to flash and then the set turns off. Purchased a new lamp ($131.00) and that did not change anything? according to the book when the TIMER, LAMP, and STAND BY lights flash it is most likely a defective lamp. What else could be wrong? HELP!
  • 1 more comment
  • Anonymous Nov 07, 2007
    had the same problem after 2 years. changed the bulb which lfixed the problem for 4 months Now have the same problem again. Bulbs should last longer or there's some other issue .
  • Anonymous Nov 16, 2007
    after 2 years replaced the bulb. 4 months later have a similar problem but a new bulb doesnt fix the problem. A new balast also does not fix the problem. Now waiting in a DMD board. The cost to fix is starting to mount. I would not recommed SAMSUNG to anyone.
  • Anonymous Mar 28, 2014
    I get a green light flashing for "lamp" a green light for Timer but the TV does not come on
Did you order an ORIGINAL REPLACEMENT LAMP? There's lots of guys out there claiming to sell original lamps but there really not the original. For Samsung TVs (The majority of them) use Philips branded lamps. Check and make sure you lamp is a Philips lamp. Check out FixYourDLP blog for more information as there's lots o interesting reading there
Posted on Jul 26, 2007
I replaced my dad's color wheel and that fixed the problem.
Posted on Aug 05, 2007
    President:
  • 3,130 Answers
The lamp drive Circuit. There is a Ballast that could be bad. The ballast is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96-00690A&search%5Fmodel=HLP4663W Or the DMD board located here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00678B&search%5Fmodel=HLP4663W Or the power board located Here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D02141A&search%5Fmodel=HLP4663W Good Luck
Posted on Jun 20, 2007
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
I have a SAMSUNG 46" DLP HL-P4663w, No picture but have sound. All three lights are flashing at on/off button. Installed new lamp ( BP96-00826A ) still no light. There is a loud humming sound.
Hi:
This is and indication of a bad color wheel assembly, you can replace the color wheel yourself, there are lots of Youtubes videos on how to do this.
Jun 12, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Sounds like you have a bad color wheel assembly which is located in your light engine assembly.
pt#BP96-00250A
Nov 26, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
626 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
