Question about LG Flatron 775FT 17" CRT Monitor
Monitor light blinking
Hello sir,
red ,orange, green led alternet blinking.
my lg flatron 775ft 17" inch white monitor
  • rponti Jan 29, 2009
    I had the same problem before but not anymore..how to fix it? in my case, i just gave the lower back part of the monitor a kind of semi-angry knock then it suddenly worked!. It's working till now.
  • LG Master
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Hello! I have a problem with my LG 775FT monitor. I have used it for about 6 months. Everything was fine, and now I have a problem with picture. Its not steady. The brigthness its OK, just the picture is...
There's an internal hardware problem in your monitor, possibly cold soldered or defective electronic part/s. please bring the unit to an authorized service center for proper diagnosis & repair of the unit. best regards
May 13, 2009 | LG Flatron 775FT 17" CRT Monitor
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Don't turn on
try to replace the horizontal output. dela cruz repair shop cdo phil.
Nov 22, 2008 | LG Flatron 775FT 17" CRT Monitor
No signal
can you please help me?
I want the software driver for LG775FT for windows98. can you please send me through e-mail?
my e-mail is ::
jigneshnpd@rediffmail.com
thanks
Aug 20, 2008 | LG Flatron 775FT 17" CRT Monitor
Drivers
go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Dec 14, 2007 | LG Flatron 775FT 17" CRT Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
LG Flatron 795FT - Led blinking
there is a step by step procedure 1.check the power cord. (try with a new one) 2.check the monitor on other pc, even if it is not working on the other pc, then carry to a service centre. 3.if it is working on the other pc then check the vga slot/card of your pc then 4.try to change the vga card and try connect an other monitor to your pc. so basing on this you will be able to trace the problem. 5.still the problem persists the consult the service centre.
Apr 05, 2007 | LG Flatron 795FT (White) 17" CRT Monitor
LG Flatron 775FT 17" CRT Monitor Logo
543 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Teet Bergmann
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
