Question about Bose Acoustimass 15 System
BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
I just purchased a Bose Acoustimass 15 speaker system through Craiglists, and the subwoofer component dosen't appear to power on. Not having owned one of these before I'm not sure if a light is suppose to light up somewhere when the system is turned on -or if some sort of sounds is suppose to initially emit from the subwoofer initially. Can anyone shead some light on this(? - also (just in case) is there some sort of fuse or something else that I could look at checking if the box is not firing-up? (thanks)
  • sjhill01 Apr 21, 2009
    I'm having the exact same issue with my subwoofer. I'm going to crack it open and check for that fuse!
I will try as best I can... There is no light on the unit. There is a two position switch, that's your on/off switch located on the botttom of the unit next to the pwr cord input... When the straight lined side is pushed down the unit is energized. When you pwr up the unit you should hear a light bump, not a cracking noise. There is a fuse on the main input/output board that is pretty easy to pop and swap.
Posted on Feb 10, 2009
  • 3 Answers
All I did was unplug my surge protecter for a 1 minute and once I did that I had bass from the module again.  I am using a Belkin PURE AV power console.
Posted on Feb 11, 2009
I aquired Bose Acoustimass 15 surround sound through home purchase. Hooked wires up to reciever and hdmi to tv and i got nothing. my question is, how do you turn on the sub? just plug it in?
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
Aug 02, 2014 | Bose Acoustimass 15 System
I have a bose acoustimass 15 bass module and when I turn it on all I get is a continuous thumping sound
okay i think you may have a problem within your connections i dont think its internal like a bad component or something such as that but make sure your wires are in good condition and most important they are hooked up properly and that should take care of your problem
Mar 19, 2013 | Bose Acoustimass 15 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
Bose Powered Acoustimass 30 Speaker System
The master on/off switch will usually be on the back (or maybe even the bottom) of the largest component, which contains the power and control circuits.
Nov 28, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System no power
same problem, i found the transformer looks like the wax or glue melted down on the cir board . . . not sure if that the problem but has anybody seeing the same ?
Sep 20, 2008 | Bose Acoustimass 15 System
Acoustimass 9
Acoustimass 10 IV cable
Feb 29, 2008 | Bose Acoustimass 15 System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
4,430 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
