Question about Fuji FinePix S9000 Zoom Digital Camera
FinePix S9000 Hey everyone. I just want to report that my s9000 stopped working with batteries. It does however work with the Ac/Adapter. Is there a fix for this. The camera won't even turn on with new batteries/ but works fine with the ac/adapter plugged in. Can anyone help. DOes anyone else have this problem?
  • 2 more comments
  • Anonymous Dec 08, 2007
    You insert brand new batteries but they do not last for more than a few shots.
  • raeho Oct 30, 2008
    I have the same problem. Out of the blue, my S9000 stopped working. It's definitely not an issue with the batteries.
    Does anyone have a solution?
  • olivier04 Dec 31, 2008
    Hi, even with brand new alcaline batteries it stoppes at 1,41 volt instead of 1,2 when I bought it
  • Linda Estridge Jan 21, 2012
    I have the same problem and i think it is one of the battery contacts that is the problem. I have cleaned them but did not help. Trying to find a battery compartment to replace it and hope that works.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
Posted on Jul 12, 2007
I have found this happens often with batteries if you've half charged them in order to use them in a crunch. However, I've also found the S9000 has a feature that discharges the batteries so that you may once again fully charge them (check your user manual). Also...keeping batteries in your pocket or other place close to keys or other metal items will not only drain the charge but in some instances cause the batteries to leak or explode. Be careful!
Posted on Oct 28, 2008
S9000 camera shows batteries to be discharged, but battery tester shows all four to Duracell copper tops to be fully charged. Any suggestions?
There could be a malfunction of the camera.
When something is blocked in the camera, the electronic will shut down, to prevent extra damage. Sometimes the lens is stuck and won't come out. This could have lots of causes, but it could overheat the motor or bring extra damage to the gears. In those cases the batteries can be drained very quick.
Sure you checked all contacts of the batteries? They should be clean and shiny. Never use a sharp tool to remove oxide or grease from electronic contacts Only use a dry cloth or special contact oil.
Nov 10, 2013 | Fuji FinePix S9000 Zoom Digital Camera
My finepix s9000 will not turn on, it clicks a few times and then there is no power on screens or other features
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
Jul 09, 2010 | Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
I NEED SOFTWARE OF FINEPIX S9000
http://www.fujifilm.com/products/digital/download/index.html
Go to the above link: Hopefully you will be able to find most of the software for Fuji FinePix S9000.
Please do rate the response and thanks for using FixYa and good luck.
Mar 04, 2009 | Canon PowerShot S5 IS Digital Camera
Initializing picture cards for Fuji FinePix S9000 digital camera
As you have downloaded all the pics to ur computer. Take the card in ur hand, wipe it's copper plates firmly with your thumb, Insert the card in your camera and format it. It should start working. Mine worked.Good Luck
Jul 15, 2008 | Fuji FinePix S7000 Digital Camera
Adding lenses to s9000
Yes. but only the conversion lens
Mar 05, 2008 | Fuji FinePix S9000 Zoom Digital Camera
S9100
they all do this to save battery power.
I believe the menu has a setting to adjust the time, but my camera is being worked on now and can't confirm this.
Nov 23, 2007 | Fuji FinePix S9000 Zoom Digital Camera
It Isn't Working
I just today sent my camera to Fuji to have the same thing repaired. I've read that the on-off switch tends to fail on this camera.Mine is just a few months past warranty, of course!
this is my 3rd Fuji and 1st problem though.
Good Luck.
Nov 11, 2007 | Fuji FinePix S9000 Zoom Digital Camera
IS or AS on the S9000
Fuji does not have either, only an AntiBlur mode that favors high shutter speeds to combat both camera shake and action blur. Fuji may be betting that their high ISO capabilities allowing higher usable shutter speeds will make IS or AS an unnecessary feature. In a few weeks when the cameras hit the shelves we will know better how this really pans out.
Aug 30, 2005 | Fuji FinePix F10 Digital Camera
Open Questions:
Fuji FinePix S9000 Zoom Digital Camera Logo
215 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
