Question about Innovage 69420210126 Phone
Does this phone have a recording?
When someone calls it just rings and rings. I thought it was a answering machine too. Can anyone help me with this problem????
  • 3 Answers
You have to hook up your own machine.
Posted on Dec 02, 2007
SOURCE:
ATT JUST INSTALLED UVERSE. PHONES WILL NOT RING AND ANSWERING MACHINE DOES NOT RECORD LEFT MESSAGES
The best thing to do is to call them back and have them send someone over. sounds like it was not setup the right way. They should have made sure eveything works before they left.
Feb 01, 2014 | Panasonic KX-TD7896 Cordless Phone
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
Jun 06, 2009 | Vtech CS5121-2 Cordless Phone
When someone calls me the ringer on the phone does not ring.I do not know how to turn the ringer back on. Also when someone tries to leave me a message the answering machine does not record the message....
On the phone not ringing, just push the volume up button while the phone is not in use, that should adjust the ringer volume. As for the message saying that calls are being routed to an automatic message sertvice, that sounds like a voice mail offering from your service provider, not the phone. Uniden phones have a default greeting that says "Hello, no one is availible to take your call, please leave a message after the tone" Contact your service provider and find out if you have voice mail service on your line. If you do and want to use the answering machine on your phone, you will need the service provider to allow for more rings before the voice mail service takes the call.
Mar 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
HELP
buy a new answering machine, this one is toast
Aug 19, 2007 | AT&T 1738 Digital Answering Machine
GE Telephone answering machine will not work
I'm assuming this is a digital recorder and does not use a tape. Any chance the memory is full and you need to erase messages to free up space for new recordings?
Jul 01, 2007 | GE 29897GE1 Corded Phone
Open Questions:
See all Innovage 69420210126 Phone Questions
Innovage 69420210126 Phone Logo
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
