Question about SAMTRON 95P 19" CRT Monitor
Getting my samtron to work on my cctv
Im trying to connect my samtron to my cctv system. the cctv lead plugs into the back of the moniter, but when i turn it on it says "no signal"....
  • 40 Answers
Make sure you are using the right input on the monitor.
Hook a camera directly up to the back of the monitor and see if you have an image.
Posted on Apr 29, 2009
  • 91 Answers
Pls Use NTSC to VGA or PAL to VGA convertor , u didnt mentioned the clour system of ur cctv camera
Posted on Apr 13, 2009
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Posted on Mar 18, 2009
2 Suggested Answers
StorminP
  • 64 Answers
SOURCE: hook my moniter to my cctv system.....
YOU need a CCTV monitor...problem solved. Yes it will cost you money.
Posted on Sep 11, 2009
I am a technician.My Samtron 56 V moniter dead. Some time switch on when power is connected after 10to15 minutes. Please give a solution.
If you have Samtron 56 V monitor that sometimes switch ON for 10 to 15 minutes, then it is a signal of some internal device fault which needs to be rectified from certified hardware technician from monitor manufacturer service center itself. It is recommended to directly contact Samtron for hardware replacement if it is under warranty or ask to repair it.
GuruAid.com
Jun 24, 2016 | Samtron Computers & Internet
If I have an LG LCD screen being used for my CCTV system ideally I want it left on. Will the screen burn like a Plasma of will if be ok left on all the time?
all t.v`s plasma lcd crt will burn an image if left for long enough idealy you should get a moniter for cctv system as they are built for the job
Hope this helps
John
Mar 03, 2011 | Computers & Internet
My moniter says no signsl but the windows is working and i checked the moniter to my laptop and it works fine
Believe it or not but theirs an order in witch you should connect up a compute,r but first make sure that there is only 1 VGA port ie (monitor socket) on the back of it. But if theirs 2 then try the other one.
Other than that try this:
Unplug EVERYTHING! even the power leads from the back of the monitor & pc.
1.Press the power button on pc & monitor to flash out any power left in them.
2.plug in & tighten the VGA cable to the pc then to the monitor if required.
3.plug in all other peripherals ie USB / MOUSE / KEYBOARD etc...
4.plug in the power supply to the monitor then the pc.
4.Switch on the power supply to the monitor first then the pc.
5.Switch on the monitor by it's power button then the pc right after it.
Jul 02, 2010 | Acer X193W LCD Monitor
Getting sound through mogen lcd tv
Yes, you need a 3.5mm male mini stereo to male mini-stereo cable. Plug into small hole in monitor to lime green port of computer352d_2.jpg
Jul 06, 2009 | Computers & Internet
Looking to buy a moniter
I have two monitors.
I don't use them, because I used and adapted the cameras in another cctv system.
You can see a picture of them here
http://www.palleyd.com/ssc-12m-monitor.html
Jan 19, 2009 | Samsung Weather Resistant Security Camera...
Hook my moniter to my cctv system.....
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Samtron vga cabal color coding problum
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Jan 23, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 95P 19" CRT Monitor Logo
215 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
