Apple iPod MA446LL/A MP3 Player Logo
Posted on Jan 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi We have an 8 year old PC running windows XP, iTunes 6.0. My wife wants to download some stuff from the itunes store, which prompts us for an upgrade. Have now been round the same loop about 8 times -> Download itunes -> run -> thank you. Nothing has changed! Help please if possible Nigel
Steve Brown
Level 3:
President:
  • Apple Master 688 Answers
  • Posted on May 17, 2009
Steve Brown
Apple Master
Level 3:
President:
Answers
688
Questions
Helped
394058
Points
2264
Delete your current version of itunes by going into
Control Panel----Remove Programs---click on iTunes 6 and Right click and uninstall.
then go to http://www.apple,com/itunes/
and download a clean version.
Install it and your all set.
tip
How to re-create iTunes library
Follow these steps:
1. Quit iTunes.
2. Locate your iTunes folder.
For Microsoft Windows XP and 2000 the iTunes folder is stored in
System drive\Documents and Settings\username\My Documents\My Music\
For Microsoft Windows Vista the iTunes folder is stored in
System drive\Users\username\Music\
3. Open your iTunes folder.
4. Drag the iTunes Music Library.xml to the Desktop
5. Drag the following file from your iTunes folder to the Trash:
Microsoft Windows: 'iTunes Library.itl' (in versions of iTunes prior to 4.9 this was called 'iTunes 4 Music Library.itl')
6. Open iTunes.
7. From the File menu, choose Import.
Note: Do not add any music into iTunes at this point.
8. Navigate to the iTunes Music Library.xml file on the Desktop.
9. Click Open.
After re-creating your library, any devices that you sync with iTunes (Apple TV, iPod, etc) will see your iTunes library as a new library and will completely re-sync.
on Jan 06, 2010 • Computers & Internet
3answers
Itunes will not install on windows 7 64
you might have the wrong itunes
http://download.cnet.com/apple-itunes/3000-2141_4-10235268.html
Version 10.6 of iTunes brings a handful of enhancements to Apple's ubiquitous media software, and adds support for 1080p video.
Windows XP/Vista/7
hope it helps
2answers
Hi I am unable to use itunes on my computer. I installed and its asking to turn off the compatibity mode. And also I cannot view summary, photo etc tab on my iphone device.
Hi
First of all
1. Exit out of iTunes.
2. On the Windows Start Menu select Computer or My Computer Depending on the OS
3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit)browse to C:\Program Files (x86)\iTunes.
4.Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
5. Next select the Compatibility tab.
6.
Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
This should fix your problem.Still if your facing the same problem after performing the following steps:-
7. Open the Registry Editor by selecting the Windows Start button, typing regedit into the search box or the run box depending which OS your using eg- xp,vista,7 and then pressing Enter.
8.
Browse to the following location in the registry editor, HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers, and highlight the Layers folder.
9. Delete the entry for the iTunes application (iTunes or iTunes.exe).
10. Close registry editor and restart the computer
You should now be able to open iTunes without receiving the error message about iTunes running in compatibility mode.If not please reply
Thanks & Regards
LOnG LIvE tHe GeeKs!!!!!
Why itune cannot connect to the store
ResolutionClick on the description below that most closely matches your iTunes Store situation:
I have been unable to connect for less than 24 hours Try quitting iTunes and reopening it. If the issue persists, it's possible the store is temporarily unavailable for maintenance. Try again in a few hours. You might want to check the iTunes Store discussion board to see if a connection issue is impacting many other iTunes Store customers.
iTunes Store Discussion Board (Mac)
iTunes Store Discussion Board (Windows)
I have been unable to connect for more than 24 hours on a Mac. If you haven't been able to connect to the iTunes Store for more than a day—and other customers on our discussion boards aren't experiencing similar issues—a software or internet service provider (ISP) configuration issue may be blocking your access to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
  • Your copy of the iTunes application may be out of date. If iTunes is out of date, it will not be able to connect to the iTunes Store. You can download the latest version of iTunes from our website:
    http://www.apple.com/itunes/download/
  • You may need to reset your keychain. Connection issues are occasionally caused by keychain issues. Click here to find out how to use Keychain First Aid to resolve this issue.
  • You switched to a new ISP. If you didn't install new networking hardware, your ISP may be blocking access to the iTunes Store. Let your ISP know about article TS1629 which can help your them configure their servers to allow iTunes Store traffic through.
I have been unable to connect for more than 24 hours on Windows. If you haven't been able to connect to the iTunes Store for more than a day —and other customers on our discussion boards aren't experiencing similar issues— a software or internet service provider (ISP) configuration issue may be blocking your access to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
  • If you have not done so, try the steps in this article to troubleshoot iTunes Store connectivity in Windows.
  • You upgraded to Windows XP Service Pack 2. Windows XP Service Pack 2, by default, enables the Windows Firewall. As with a third-party firewall, you will need to configure Windows Firewall to allow iTunes to access the iTunes Store. To do so:
    1. From the Start menu, choose Control Panel.
    2. If the Control Panel is in Classic View, skip to step 3, otherwise open Security Center.
    3. Open Windows Firewall.
    4. Click the Exceptions tab.
    5. Select the iTunes checkbox to enable it as shown here:
      2. Click OK.
      If you have further questions about configuring the Windows Firewall, contact Microsoft's Service Pack 2 hotline at (888) SP2-HELP. Read this article for compatibility information.
    6. You switched to a new ISP. If you didn't install new networking hardware, your ISP may be blocking access to the iTunes Store. Let your ISP know about this article which can help your them configure their servers to allow iTunes Store traffic through.
    7. The "hosts" file may be blocking the iTunes Store Instructions for Windows 2000 and XP: Find your hosts file. The hosts file is normally found in the following locations:
      Windows XP: C:WINDOWSSYSTEM32DRIVERSETC
      Windows 2000: C:WINNTSYSTEM32DRIVERSETC
      1. Select the hosts file. Then click the Edit menu, and choose Copy.
      2. Then, click the Edit menu again, and choose Paste. There should now be a duplicate of the hosts file named "Copy of hosts".
      3. Drag the original hosts file to your desktop.
      4. Right-click the "Copy of hosts" file and choose Open. You may be prompted to choose the program you want to use to open this file. Double-click Notepad.
      5. When Notepad opens, click the Edit menu and choose Select All. Then click the Edit menu, and choose Delete.
      6. Click the File menu, and choose Save. Close Notepad.
      7. Right-click the "Copy of hosts" file, and choose Rename. Type "hosts" (without quotation marks) and press Enter.
      8. Restart your computer and try connecting to the iTunes Store.
      • Make sure that your computer meets the iTunes minimum system requirements.
      • Make sure that your operating system is up to date:
        • For Mac OS X, use Software Update to determine if you need to update your system.
        • For Windows, go to Microsoft's Windows Update webpage.
      • Make sure that you can access the Internet on your computer.
      • You may have firewall or other security software that is preventing your computer from connecting to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
1helpful
2answers
Being 58 years old bought a nano ipod for my wife want to put music on it dont understand what to download to be able to use it ?
The first thing that you should do is download itunes from the apple website at www.apple.com/itunes once installed open up itunes and then plug in the supplied usb cable into the ipod and the other end into your computer. From itunes you can then go onto the apple store and buy music from the store or if you have music on CDs you can use itunes to pull the CDs onto your computer and from itunes and clicking on the devices section you can transfer the music onto your ipod. Hope this helps.
2helpful
3answers
My computer has itunes but every time i try to hook up my ipod it says it need a new version of itunes 8 ive tried 100 times to dowload it but am no able to what can i do?
You need to uninstall ALL Apple software (iTunes, Safari, Quick Time etc) from your PC then restart and re-download iTunes and re-install.
Hope it will solve your problem
Thank you
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Can't open certain windows after trying to install Itunes
Encarta is actually Microsoft's Encyclopedia (http://encarta.msn.com). Did you try uninstalling iTunes at all?
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
