Question about Canon NP 6545 Copier
Error e020 everytime i put the machine on its says switch power off and on. i did this several times and still it repeats the same message. i really need to use my copier badly. i work in school and i need copies made. please help. is there anything that i can do myself to resolve this problem. your help would be deeply appreciated. thanks.
  • 432 Answers
The developer unit is looking for toner from the hopper. E020 can also be the DC Controller or the developer unit itself. The toner cartridge is probably fine. This can be complicated to fix. The copier is probably still under warranty. It's better to call up Canon 1-800-828-4040 and have them send out a Certified Technician to fix this. Sorry I couldn't help more. Ray
Posted on Jun 20, 2007
SOURCE:
I have a Brother 4150CDN printer and have an error message EF
Please make sure the machine is plugged directly into the wall without using anything in between (UPS, power bar, power inverter, etc) Turn OFF the Brother machine's power switch (located on the right side of the machine near the back), and then turn the switch back ON.
Print the demo page by pressing FAX and COPY at the same time.
Repeat the task that was being performed at the time the error message appeared. If you are unable to repeat the task for some reason, print a document from your computer. If the machine is not connected to a computer, make a copy of the test print.
Oct 05, 2018 | Brother Office Equipment & Supplies
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
We were copying and the error code E020 04E0 came up
Error code E020 04E0...there's an error in the developer unit...check the developer unit and see if it's working properly...
Jun 23, 2009 | Canon CLC 1150 Color Copier
Error Message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Thanks.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Dec 24, 2008 | Canon CLC 1180 Copier
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Canon photocopier
Title : E020 Error Code Problem :
When you have followed all the steps from the troubleshooting guide in the Service Manual and still have not resolved the issue, here are some possible areas that might be related.
Solution :
1) Confirm that the toner and hopper sensors are being wiped completely.
2) Check the Gear Train on the hopper assy it may be locked up.
3) A possible bad hopper unit cable. FG5-5016-000. See The Parts Catalog page 620-2 item # 60.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Jun 27, 2008 | Canon NP 6050 Copier
Canon NP 6545 Copier Logo
91 people viewed this question
Clive
Clive
old marine
old marine
Ekse
