Question about Hitachi 43UWX10B 43" Rear Projection Television
Black Screen, No Sound
About a week ago I noticed that the picture would go to brown tones and then fade to no picture, after the TV had been on for about 30 minutes. Then, all failed - i.e., I still have power, but have no picture and no sound. Help!
    President:
  • 3,130 Answers
There are numerous problems that can make this TV set to be dead. The most common is the coolant fluid between the picture tubes and the lens leaks out onto the boards below the picture tubes. You can verify this by looking at the boards. you will see a small puddle of oiley liquid or an indication of moisture damage. If that is not the case. You can get the service manual and look up the trouble shooting flow chart that Hitachi puts into their service manuals. I happen to have a copy I could share with you if you wish. You will of course need to know what to look for and understand how these solid state circuits work inside of this TV set. If you do not understand about this TV set's circuits, play it safe and call in a pro to assist you with this repair, as this is not a place to be experimenting around inside of. Good Luck
Posted on Jun 20, 2007
  • Larry  Dillon
    Larry Dillon Jun 20, 2007
    oh leave your e-mail address if you want that service manual.
SOURCE:
My picture fades out, I have sound can't change the channels?
soundslike you need a new TV or get this one repaired .
Aug 08, 2016 | Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Color on TV changes to black and white, then after awhile changes back
It is possible to be the box, and not your tv. A good way to test is to see if it does it when you are watching a dvd or another source. (game system, blue ray, ect) Hope this helps! Good luck!
Dec 04, 2013 | Televison & Video
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Samsung LCD TV faded area
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 09, 2017 | Samsung Televison & Video
TruTech PLV1615T has Sound but No Picture
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Aug 06, 2008 | TruTech PLV1615T 15 in. LCD Television
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
