Question about Sony Playstation 3 (PS3) Console
When i turn on console nothing happens
No menu is displayed, just a blank screen. when i put in a disk, a small loading symbol appears in the top right hand corner, but again, nothing happens.
  • keith_fairgr Jan 17, 2009
    this worked first time, excellent advice, thank you so much
    Guru:
  • 859 Answers
Is this a new system? The PS3 is having problems with some disc drive bays.
So, go to this link below to find the method to do a full system reset and then use a CD Disc that is designed to clean the lens of the laser.
Visit the official PS3 website for repair options.
Posted on Jan 17, 2009
    President:
  • 2,110 Answers
Hi Friends,
Problems with Sony PlayStation 3? Don't worry there are some main problems forPS3. These are Unable to read disks, Black screen, Freezing, Unable to play games etc. for the solutions for these problems justClick Here.
If you have any other problem with your PS3you can Click Here for solutions. May the site can help you to find your solution.
  • Sibananda Jena
    Sibananda Jena Jan 17, 2009
    OR TRY THIS...
    With the system on standby, hold the power button until the third beep.
    The system will turn on with the first beep, reset the settings with
    the second beep, and then turn off again with the third beep. Repeat
    this process and you will hear a double-beep at the end and the system
    will stay on and it will tell you to connect a controller via the USB
    cable.
    This will bring you to the recovery menu. Try rebuilding the database or restoring the file system.
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Blank menu screen ps3
Hi and thank you for using fixya:
You said you see a blank menu screen. What are the options on the menu? what do you see exactly. While your console is on press down the power button for 30 seconds to restart to factory settings.
Good luck
May 02, 2010 | Sony Playstation 3 (PS3) Console
Corruption, successful restoration then system failing to load.
manually do a system restore. warning you will lose saved data.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Full Desktop does not appear, video does not show.
You must tell the laptop to change display mode--there are 3...Normally, the key-press is something like "function key, F4"--look for a small tv screen symbol on one of the "F" keys--default mode is "laptop only", Press and hold "fn" and then press the appropriate "F" key, the laptop will switch to "laptop/external display". Another set of key presses will get "external display only" mode. And, finally, the next sequence will bring you back to the default mode. Make sure you turn on the computer and *then* turn on the projector to head off any sync probs.---Rick
Sep 21, 2009 | CTX Optoma EzPro 710 Multimedia Projector
My son was messing with the controller, and it came to a screen with different languages. I kept trying to go back, but wouldn't let me. so I restarted the console. When it came back on it was stuck on the...
I can bet you that your xbox 360 is vertical? am I right? If no then my disk holder gets jammed a lot, so i would get 2 small flat head screwdrivers and pry it open. So put your xbox 360 horizontal. This would also fix the problem. If your son still has the language screwed up u have to learn some spanish or watever it is to figure out how to put it back. It would be on profile settings.
Aug 14, 2009 | Microsoft Xbox 360 Console
My PS3 turns on and gets to the home menu screen but when I select the saved data to load a game nothing happens - therefore I cannot load any game?
Sounds like your trying to play the game with no disk ? when you put the game in that you want to play it will either load by its self or ask if you want to load. hope this helps rate me please
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont load any games
try holding the power button down for 5 sec this will do a manual reset, if that doest work make sure you video cables or hdmi is tight
Mar 01, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 won't recognize media, i.e. DVDs, games
So your DashBoard doesn't even come up at all? What happens when you turn the PS3 on with the game inside of it? Try using a lens cleaner to see if it is perhaps your laser that is being blocked by dust or something. If nothing works you may need to reload the PS3 Operating System (OS).
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Different Problems
This is Phobos92.
It turned into the red ring of death. So no further help needed.
Feb 26, 2008 | Microsoft Xbox 360 Console
BLUE-RAY DRIVE
try putting a laser head cleaning disk in.
Check that the machines region coding is the same as the country your in.
You may only be able to play JAP Or NTSC-J Games on this Console, due to region compatability restrictions.
Feb 11, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
