Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Fails to start Midea dishwasher WQP12-9240AS
After turning dishwasher button on. Wash light flicks and machine beeps this continues for about 20 seconds or so. then machine seems to try and start but after another little while it stops with wash light continuing to flicker.
  • 2 more comments
  • Anonymous Mar 31, 2009
    I have exactly the same problem!!
  • Anonymous Apr 28, 2009
    Exactly the same problem, wouldn't start and the light is flushing and beeping for a about 20 sec. and then stops. What to do?
  • thebigtommy May 06, 2009
    Same problem for me too
  • Anonymous May 20, 2009
    Same, wash light flashes. will not continue cycle.
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Posted on Jul 14, 2015
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
Poohs
  • 4 Answers
SOURCE: cycle wont run and lights on main washes flash
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
SOURCE: hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Posted on Mar 07, 2008
SOURCE: Midea dishwasher WQP12-924OA wont go
hold power button down for 10secs while plugging in mains
Posted on May 07, 2008
  • 7 Answers
SOURCE: Hotpoint FDW60 problem
hi
you will proberbly find that you have a control module fault.
connection from you heater and or thermostats faulty.
if your heater was open curcuit it would flash fault codes.
Posted on May 18, 2008
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Apr 26, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
1,837 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
