Question about RCA PDP 2812 (5 GB) MP3 Player
My Middle Button is Loose
Does anyone here know how I can get my middle button fixed? It's been loose for quite some time and before I used to still be able to control the music, now it's not even usable. Please inform me of anything you might know about how I can get this fixed. Thank You.
SOURCE: file system corrupted
Fist you press the middle button, far on you press the on button, then you press the music and what not button and it should work just fine if you have and questions about computers just email me
Posted on Dec 26, 2008
0 characters
1 Points
My zune 120gb stuck on contact support page and can't pay 18-30 u.s dollars to get help from support, should i throw mines away i'm fed up with problems comming up where i have to pay MORE money to fix.
no, dont just do the following On your zune make sure the hold button isn't on
At the same time hold down the back button and upwards on the directional pad until the screen goes black
then use your left hand and press the back button while using your right index finger to press the middle of the zune pad use your middle finger (on your right hand) to press play pause button. All of these need to be held at the same time. You should get a please wait message. follow the instructions on screen.
Jun 06, 2010 | Microsoft Zune JS8-00001 Digital Media...
New iPod Nano Stuck on Logo Screen
Is it charged, plug it into your computer and leave it for a while. Then try and access it through itunes (if it shows up) and restore it.
Oct 28, 2009 | Apple iPod nano
How can I use Zan nano plus 1GB Mp3?
ok from what i know of that model the middle button should be a multi function button try pressing and holding it for a short time and see if that brings up a menu of some kind then use the fast foward/reverse buttons or the up/down buttons to navigate thru the menu once your on the music menu or whatever try pressing the middle button to select it
im sorry if this is incorrect but its an attempt hope im right :)
Sep 30, 2009 | Creative Labs Zen Nano Plus MP3 Player
press the MIDDLE BUTTON and MENU button at the same time
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
My zune middle button won't work
well i had the same problem for about 3 months...i tried doing research and found a website... took my zune apart and then followed the steps only till step 5..then i let it sit out like that for about and hour, then i put it all back together and my buttons work..there is also video on youtube for problems like this, simply go to youtube and type in <Take apart zune to reset (doesn't work)>
Jan 20, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Ipod chromatic
you have to reset your ipod, it went into like this freeze mode. It happens to me all the time. You have to hold down your menu button and the middle button at the same time. After that it should blink on. Give it a shot
Jan 03, 2009 | Apple iPod nano MP3 Player
My ipod middle button doesnt work what can i do help
This usually happens if the membrane of the action button deteriorates and the gold plated contacts between membrane and logic board do no longer establish good contact.
There are specialized online tutorials with iPod Repair instructions that will guide you through the steps of taking it apart and cleaning the contact or replacing the button altogether otherwise you'll have to send it to any third party iPod repair service and they'll replace the membrane for you.
Sep 30, 2008 | Apple iPod nano 2nd Generation MP3 Player
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
Sansa mp3 player stuck on different laguage
For the Sansa Clip:
Turn device on
Scroll to Equalizer looking thing (box with 4 sliding levers)
This is the settings function Select it by pushing middle button
Hit the scroll down button 3 times or scroll to the option right above the one that has FM
Scroll up or down until you see english
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
RCA PDP 2812 (5 GB) MP3 Player Logo
15 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
