Question about Philips 32PF3320 32 in. HDTV-Ready LCD Television
Philips 32pf3320/10 - No picture, has backlight & sound
Hi, I have a Philips 32pf3320/10. The other day the screen went blank, the backlight is still working and there is sound. The display eg. Volume, channel number, menu (dont know the proper name for this) has dissapeared also. Any help would be appreciated. Thank you.
5 Suggested Answers
  • 7 Answers
SOURCE: philips magnavox plasma tv model 42mf7010/17
Turn off the video mute if it has this setting. Try using a VCR tuner and connect the VCR to the TV on AV1 or AV2 inputs. THis fix is free until Feb. 09. After that, you will need a DTV converter box or pay for a cable/sat box.
Posted on Jul 22, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
  • 138 Answers
SOURCE: '42pf9630a 37 philips tv only displays menu
Check the software and if is not BX23U-1.5.0.0_03531 upgrade it by downloading the software onto a usb stick at www.p4c.phillips.com if that don't fix the issue replace the SSB part number 310432842611
Posted on Aug 19, 2008
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
  • 14 Answers
SOURCE: philips pfl6704d all the buttons on the tv turn
did u have service your tv? some times when set back the pcb board, it's not really in it's position n the switch of button is pressed
Posted on Sep 19, 2009
What do I check
take it in for a repair quote and if fixable at a reasonable price fix what is quoted
Jun 13, 2016 | Televison & Video
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Screen show no display/ only blank.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Screen is blank
Your backlight finally went out. If doing it yourself, you need to order 2 to 4 backlights along with an inverter. It is good to replace both at the same time. The backlights are like mini floresent tubrs that need to be taken out and replaced by some one who has done it before. The cost will run you about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Philips 32PF5320A 32 in. LCD Television
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
51" Magnavox projection TV
same with mine. Two things that they have to install and they need the whole tv there to fix it and run it for a week. Cost 500.00!!!
Aug 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 32PF3320 32 in. HDTV-Ready LCD Television Logo
302 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
