Question about Dell E173FP 17" LCD Monitor
Monitor powers up/flashes on briefly, then screen goes black
The power light flashes green and clearly the monitor has juice and the proper power as the home screen looks right if just for a second. Then it turns black and I can't get it to work again. I was hitting the side of it for a couple weeks and it would power on no problem but now it wont ever get past this initial freak out. this sounds like a common issue? help!
  • 2 more comments
  • Anonymous May 31, 2008
    SCREEN ON. GREEN POWER LITE BEGINS FLASING. SCREEN GOES DARK AND ONLY WAY I HAVE FOUND TO BRING BACK ON IS TO STRIKE THE FRAME OF MONITOR IN PLACES.
    RUSS HAYCOOK
    [email protected]
  • Anonymous Jun 08, 2008
    SAME AS ABOVE
  • Anonymous Jun 29, 2008
    monitor flashes startup box, then just blinks and goes black permanently. power light is still green though.
  • larosa2rocky Jul 11, 2008
    I have the same problem the green light blinks, and the screen stays dark . if i tap the side it works perfectly for about 2 day's.
I had the same problem... someone somewhere on this site suggested to turn the brightness down to <57%. Took me ages to do as the monitor is only a couple of seconds on. So basically tried it blind with the monitor function buttons and when I was less than 69% suddenly it worked... I have now my own theories why I run into monitor problems: AOL latest updated prompted me to change the desktop resolution setting to 1024 x 768 pixels, 32 bit which is theoretically possible but puts an electrical strain on the conduits... I've now changed it to a medium setting of 960 x 720 pixels, 32 bit which is still o.k. and the maxium brightness on the monitor to 56%. As I say, it took me ages to figure it out: at least I got around driver updates or even purchasing a new monitor... Good luck to you, mate. Hope this helps to you or anyone else who has the same problem. SpeedySpod
Posted on Jun 24, 2007
See the best solution on: http://www.fixya.com/support/t116490-monitor_shuts_off_but_green_light_stays It worked for me!
Posted on Jun 20, 2007
SOURCE:
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor will appear to come on a "no signal" sign flashes up then the screen goes black. If you press the on off swich the green light will come on briefly then go to orange and then disappears completely...
could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Jun 28, 2009 | Westinghouse L1975NW Monitor
Computer monitor flashes on then turns off
Try the monitor with another computer. If it works, the video circuitry (whether it is on-board or a separate adapter) in the Gateway is the problem and needs to be replaced. Otherwise, the problem is with the monitor itself. From your description it is probably the Gateway's video that is the problem since the power light on the monitor remains green indicating that it is seeng a signal, but not something it can properly interpret, i.e., one or more of the control signals are shot.
Mar 21, 2009 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Dell E173FP 17" LCD Monitor Logo
325 people viewed this question
Ekse
Clive
Clive
