Question about AEG Lavamat 88840 Front Load Washer
AEG Lavamat 6955
Does anybody know what F8 means in the lcd panel ? The machine still completes its full washing cycle but F8 is not mentioned in the manual.
  • Anonymous Mar 15, 2014
    Machine stops and reverts back t start of cycle
Replace door seal
Posted on Jul 26, 2007
SOURCE:
Washing Machine AEG Lavamat L64850 - cant change the washing time?
Not all of the options on the AEG Lavamat L64850 are available with every cycle. The Time-savings option isn't compatible with the 40-60 Mix program. See ManualsLib, https://www.manualslib.com/manual/555025/Aeg-Lavamat-L64850l-7kg.html?page=16#manual , for the various washing programmes and the available options.
You can get the full manual for your washer at AEG, https://www.aeg.co.uk/support/download-manuals/ . There are several models listed. The direct link to the manual for the L64850L/91452556002 is currently http://www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL=2013\132\950431EN.pdf .
I hope this helps.
Jun 14, 2018 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
My wash-machine, AEG oko lavamat 6955, is blinking at the 1500 and 900 buttons, and is showing the code "F9" and the door will not open. How do I fix this? And if I must have a specalist to...
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Nov 06, 2017 | AEG Washing Machines
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
591 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
