Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
My pc does'nt boot up
When i turn up my pc the display turns on but it wont boot up.hope you can help me with my problem thank you very much!!!
  • Juanita Vega
    Juanita Vega May 11, 2010
    does it do anything?
    Champion:
  • 203 Answers
There could be more than one single problem, the pc has to say something on the screen, if is not say anythyng chek the conection of the monitor or try the monitor on another pc, take out any new hardware wich you put recently or changed recently. that  could ba a problem as well.
Posted on Jan 17, 2009
Acer iconic 200 wont turn on
it must b ur battery!! its nt been charged for a month...so its completely dead n may nt work , bttr go for the new one..!!!
Dec 28, 2013 | Acer Computers & Internet
How can get inside again in the boot setup of a dell optiplex 170L?
Good Day,
That is quite an easy thing to do.
Immediately you turn on your PC, after displaying the brand (for some PC), the computer dispalys 'press F__ to enter boot setup'. If you can't get to read it, either press F2, F12, F10 or F1 continously after you turn on your system. Then you can make your corrections.
I hope this helps. Thank you for using Fixya.
Jul 23, 2012 | Dell Computers & Internet
I have a gateway laptop & it wont turn on. its charge & everything.
Hi! Welcome to www.fixya.com.
Its definitely a hardware issue. You can remove the battery and ac adapter and drain the power for 10 seconds. then use only the ac adapter. Press the power button and if it did'nt turn on. You have to call your manufacturer for motherboard replacement.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | HP Pavillion ZV6000 Notebook
When i press the button to start my computer,its start but nothing on the screen and that's it... what seems to be the problem? thanks
Hi andre_naviga,
If system wont display anything after booting up, you might have a display issue. The easiest way to correct this problem is to perform a power drain. Here are the steps on how to do a power drain.
1. Turn off the computer completely.
2. Now, unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Press the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter to power outlet.
6. Turn the computer on and observe the system.
Hope it helps.
Thank you for using FixYa.
Apr 04, 2011 | Computers & Internet
ASUS Eee PC 90 XP. Wont boot only displays vetical lines.
Did you try a external monitor to see is it works mine is doing the same think so I hooked up a external monitor and the computer is booting correctly i had to hit fcn and f5 for monitor to display. I think it might be a loose connection in the laptop.
May 16, 2009 | ASUS Eee PC 900 Notebook
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Problem booting the hitachi pc phone
http://www.smartphoneforums.com/forums/hitachi-g1000/26298-my-g1000-wont-turn.html
Jan 06, 2018 | Hitachi G1000 Pocket PC
No picture sound is ok
For a desktop PC that boots up and produces the normal audio/sounds when booting but would not display anything indicates a possible problem with the video. This could be the:
1. monitor - most likely
2. video cable - seldom but if happens
3. video card - but more often would not even boot the PC>
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Apr 03, 2008 | Computers & Internet
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Mar 06, 2008 | Compaq Armada E500 Notebook
Monitor problems
wrong or incompatable display drivers.update or re install
Oct 31, 2007 | EliteGroup A530 Notebook
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
46 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
