Question about D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204)
Dsl 504 I reinstalled Windows and Driver of Ethernet has deleted.I need software for dsl 504
2 Suggested Answers
  • 442 Answers
SOURCE: Windows vista OS doesnot support to install DSL 200 modem.
The driver for this modem is located in the link below.
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-200&revision=REV_C&filetype=Drivers
Posted on Jul 29, 2009
Why am i getting an error message
this is the most solution:: I had the same problem:
"Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:\DRIVERS\APPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
good luck!
May 06, 2013 | Veo Advanced Connect Webcam
After reinstalling Windows XP, my PC can't detect
Yes you need to install the ethernet driver . You can download it here. You can either enter your service tag number which can be found on the back of your CPU or you can manually select the model. Once done, it will display all the available drivers for your device. Make sure you choose the right Operating System and download/save the ethernet driver you need. Install it ands reboot the computer. Once the right driver has been installed, your computer should be able to detect your modem again.
Hope this helps.
May 31, 2011 | Dell Computers & Internet
My computer had a virus so i reinstalled windows vista. now my ethernet/ computer does not recognize my internet modem and when i try to install it from my verizon dsl disk it says my computer is not...
After you reinstall the Operating System, you need to reinstall the drivers for the adapter as well.They do not get reinstalled automatically. You may go your computer's manufacturer's site and download the drivers and install them.
Feb 27, 2011 | Dell Ethernet Card Network Adapter
I accidentally deleted the file with my ethernet driver. How can I reinstall?
You can re-download your Ethernet driver here:
http://support.acer.com/drivers_download.aspx
Just choose your Acer model and find the correct driver. Once you've saved it to your computer, go into the Device Manager, find the network card (it will probably say "unknown" or "unidentified" if you don't have the driver installed) and re-install the driver for it. Then you should be good!
Aug 13, 2010 | Acer Aspire One PC Notebook
My e machine crashed i reinstall win xp now it will not connect to the internet using dsl device manager said that modem was working also there are no com ports showing
HI jar5. Did you install the ethernet driver after the Windows reinstallation? The DSL modem uses 2 interfaces. The USB and the Ethernet. YOu can use the modem´s Driver to use it thru the USB or you can use another computer go to the emachines´website and under support or drivers select your model and download the drivers because probably you also dont have sound, etc. I hope this helps. Please do not forget to rate and provide positive feedback for our fast - free support today. Thank you :D
May 01, 2010 | E-Machines eMachines Desktop PC
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
Receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
Jun 23, 2009 | Veo Advanced Connect Webcam
Need ethernet controller driver for sony vaio pcg-srx51p/a
Did your sony vaio came with a cd installer? If it has one, you can use that to reinstall the ethernet controller.
May 05, 2008 | Computers & Internet
Windows 2000XP Prof.(Service Pack 2)
dear mark
maybe you can try this site for your new driver
http://members.driverguide.com/index.php?action=srch&sm=b&aax=&qa6=1047&qa5=12&qa7=1500&dp=2&qm0=cdc+ethernet%2Frndis+adapter&jmd=and&fzz=d
or find with google
http://www.google.com/search?hl=en&lr=&ie=UTF-8&oe=UTF-8&q=Texas+Instruments+Network+Adapter++cdc+ethernet%2Frndis+adapter+Windows+XP+Home+
i hope this can solve your problem
thanks
cropp
Mar 13, 2008 | Computers & Internet
D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204) Logo
53 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
