Question about Samsung HLP4663W 46" Rear Projection HDTV
Problem for hlp4663w
I have a 46 inch dlp model # hlp4663w, the 3 lights were blinking in front of tv and that says that the lamp is bad. The 3 lights are blinking together and will just keep blinking all night. So i changed the lamp but now when i turn the tv on the picture will only be there for about 3 mins and then it goes black but i still hear sound. The problem with that now is that i can't turn tv off(i press power on tv and remote and won't go off) The only way i can turn it off is by unplugging the tv. When i plug it back in it does same thing(picture goes black but i hear sound) the old lamp was still producing a picture so i put that lamp back in but still was going black and i had sound. And i still had to pull the plug to get tv off. I need some help to fix the problem
  • 143 Answers
Bad color wheel
Posted on Nov 30, 2007
SOURCE:
POWERS UP W BEEPS BUT NO PICTURE THEN ALL 3 LIGHTS ON FRONT BEGIN TO BLINK STILL NO PICTURE
all 3 leds = lamp failure
if lamp is ok, it can also be the lamp driver, color wheel, or dmd board(rare)
first pull out the lamp and check that, likely your bad part, part numbers on the side of the tv, www.dlplampsource.com for parts.
let me know if I can provide further assistance.
Sep 09, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Dlp replacement lamp just now installed, but TV still won't work and (3) LED lights still blinking. Any ideas ?
Be sure the lamp cover door is closed to activate the safety switch. Otherwise the set will need a ballast or possibly the color wheel is not starting........it can be defective,especially if you have heard a whining noise prior to the set failing
Jun 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Screen wont come on
Your color wheel has gone bad. I recommend this repair to only be done by a qualified Samsung service center. Part costs less than $100
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
DLP TV Samsung HLP4663W
Your problem could be your lamp is not seeted all the way in. Take you lamp out and put it back in. Or it could be you ballast that lights you lamp is bad. You may need a new ballast.
Mar 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
367 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
